Using 172.5 and 175 crank
Dambha
Morning all
Is it advisable to use a 172.5 left arm crank with a 175 right crank...got a left arm power metre.
In theory could you increase the stack height between your cleats and cycling shoes by using something to make up that 2.5?
Any advice would be highly appreciated
Try this guy: https://drharrysportsurgery.co.za/#contact
He can make one leg longer, or the other one shorter for you.
How long can a thread go until the OP logs on again
In the old days I would have said years. This new hub, I dunno, maybe another half a page?
Yours at least had a half decent title. This one... meh
Disagree, the angle of the hip will be less putting strain on lower back and Glute
Actually there is thinking in the industry that supports what you're saying. current thinking is that the increased hip angle at the top of the stroke as a result of shorter cranks is advantageous from a leverage perspective. Many professional bike fitters and sport scientists have demonstrated that this is real and recommend shorter cranks than riders would ordinarily use.
I haven't tried this yet so can't testify to whether it works for me or not.
I was just looking at it from an injury perspective that if the knee travelled just a little higher over the top where most riders are not engaging muscle groups in that leg at full force then there is less likely to be an injury than if they over extend at the bottom of the stroke.
Can't believe this is even being debated. Just don't.
Ah, but this is hubland. We can debate even the most straight forward thing, just give us a gap.
Morning all
Maybe your left leg is shorter than the right
We all have a leg length discrepancy, maybe yours will work out right
What's Friday without a good debate????
Next week we will tackle the question of whether oxygen is actually good for you.. M. Or not.
Teaser: Too much much of a good thing...
To be fair, 100% of people exposed to oxygen die. Well, Jesus excluded apparently but I'm rounding that Stat up.
