Well, 105 is 11spd, mechanical and old tech. You can still buy Rival22 for the same price as the current 105 and its lighter.
Lets see when (if ever) Shimano brings out 105 Di2, what it will cost and what its weight will be. Until then, you are not comparing on the same scale.
Edited by JA-Q001
Yeah, the Sram needs a weigh bridge, not a scale.
85g or 850g ?     :eek:
Closer to 900g.
Thats vs a mechanical 105 disc groupset.
The only advantage is the rival goes beep.
It changes gears and stops the bike, just adding 900g. Its a groupset, apples and apples.
Not comparing it to a 105 groupset rim brake with a SI crank.
SRAM lists the groupset weight with the biggest range cassette
Shimano lists weights with lowest rnge cassette.
SRAM lists weight with batteries without cables and hoses
Shimano lists groupset weight without battery and w/o cables or hoses.
not quite apples with apples but generally teh SRAm road electronic group components are heavier. However one needs to consider what the weight difference is of working systems
So having done some research:
Shimano 105 R7020 (including all cables): 3129 gr
RRP at launch: $ 1130
SRAM Rival AXS (Including everything) :3206 gr
RRP at launch: $ 1639 incl Power meter
So an extra gear and electric shifting gives you 77 gr penalty.
Price can not be compared, because 105 R7020 is almost 4 years old.
Edit: The Rival also includes the Power meter.
Edited by JA-Q001
indeed, SRAM is listing the fullest spec group while Shimano the most weight optimistic
