  • Replies 63
2) Use the BBB goodie to create what looks like nice cable anchors for through-cable. However' date=' from what I can guauge here from my arm-chair, you'll still need to open up the holes in those cable guides. You'll need more than mere slots to get those bolts through.
You dont need to modify anything. Unscrew the small bolt and thread it back through the small end of the cable guide to that the jaws sit at the other end. Its all quite small and finicky though (2.5mm key) and you can't do it up too much otherwise you pull the washer through.
They dont sit very tight, and you still get flappy cables. They look slightly better than the zip tie option, but are quite a bit more expensive.
Brand-X also has a pair -  I saw them on CRC yesterday.
I use a system that also bolts into the cable stops but it is not adjustable. I got it from Westdene cycles but I do not know what brand it is. It looks something like this.
http://www.jensonusa.com/product/br/BR407Z55__________GUID.jpg
.....So far you have only cluttered the thread and contributed nothing. Resist the urge to chip in when you have nothing to say.
ClapClapClapClapClapClapClapClap
Well said!!
judging by the number of posts, i.e 22 000 odd vs 2600 odd.....who is the one talking crap all of the time???
Come on guys, this is a technical forum....keep it that way!!!
Holy, start a new thread in Chit chat if you want to explore the finer nuances of language use, warranty voiding, JB's personal attributes....
I started reading this topic because I wanted to know more about gear cables, housing and the effects of dust & mud....NOT this chit chat crap!!
Like the dude says in the Windhoek advert..."keep it real...."
Well said!!
judging by the number of posts' date=' i.e 22 000 odd vs 2600 odd.....who is the one talking crap all of the time???
maybe you should read how the thread started?
Well said!!
And what is you answer to that question?
yes/no/I'm unsure
Well said!!
yes/no/I'm unsure
yes.
holy roller2009-06-25 02:21:45
Guest Big H
The topic of this thread is "Drilling cable stops......" In between the literature lessons and acid remarks by Hubbers...... ooooh!!!!!...... and the piccies from Momparra!!!!!!............ has anybody ever thought how in hell are you going to DRILL a cable stop that sits right next to the frame....... with a large chuck on the drill....... JB's option of FILING carefully makes sense though!!!!!!
Oom hendrik as jy so gat sou wou boor (wat ons reeds bepaal het is 'n kuk idee) dan sal ek voorstel jy gebruik een van die klein "air" bore wat beskikbaar is . 'N Hilti sal biekie sukkel . smiley2.gif
Mampara
Are those cable guides aimed more at hydraulic brake hose? Arent dear cables slightly thinner than that? ie they might not stay in that slot.
Modifying your frame in ANY way = NO warranty.
This goes for painting and drilling.... JAAAAA I know it will do NO damage to your frame but you will have no warranty Shocked and that is it, no ums or Ahs, No warranty.Angry
Would like to hear what Borman has to say about painting bicycles.........
