it cost me about R100 to cut a basic design including material if not less then that
Will be very interested to see what you come up with.
Don't know what cutter you are using but how hard would it be to copy some Ali dropouts?
  • Replies 2k
It would not be hard at all. I have a waterjet & 3 CNC routers at my disposal so anything is possible :thumbup:
What material are you thinking of using?
I have made a chainring before out of a soft grade aluminuim but within 200km is was chewed so smitharians,
I have a design for some custom chain rings I would like cut out of 3mm S/S
Any chance of getting a 34t and 36t ring with a 104 BCD?
That can be done on my waterjet no problem. On Monday when I have a bit more time to spend doing research, I'm going to find out about the correct Ali to use. I'll keep you posted as I know more info.
If anyone has any ideas of what they want they can send me a sketch or digital drawing in DXF format to Myself at orders@rindrouting.co.za.
Hi the name is Daniel.
I thought i would share my fixie i built.
Its an old Apline 55cm frame which i resprayed ivory. it was originally blue.
Its currently got the following on it:
white halo areotrack flip flop hub and rim with a 15t sprocket want to get a 17t for the other side.
chosen front wheel
white sr suntour 42t crank
shimano tapered bb
custom made suede and leather seat
and some old school odds and ends
Let me know what you think
dan
chosen front wheel
shimano tapered bb
dan
Looking good !!
Soon to be completed... The momsen will donate some parts to "The flying Dutchman". Since I'm first generation Dutchman South Africa I thought my bike should pay some kind of a tribute to my heratige, hence the color scheme. I can't wait to put this puppy together!!
Plasti Dip Thug?
Yebo.
Red for the fork and Smoke for the frame. Gave the frame a coat of matt black first though.
