Put this together for CM this friday, will do custom paint job after i make sure she runs smooth.post-19209-0-04527900-1374746762_thumb.jpgpost-19209-0-19368300-1374746788_thumb.jpgpost-19209-0-37374000-1374746820_thumb.jpg
  • Replies 2k
Very nice. Once you get shorter chainring bolts you can remove the redundant big blade and remove a link or two on the chain, so you do not have to push the tensioner all the way up..
Here's my latest single speed bike build:
Awesome bike that's a real eye catcher for your daily commute or moonlight mass rides.
It is a 56cm lugged steel frame and fork with flat bars and a single front brake.
Mavic double wall alloy rims.
Very light (10.35kg), fast and absolutely fun bike to ride.
Selling for R3500.
Check out some of my other work on facebook - Adriano Silver
Selling for R3500.
Nice work :thumbup:
Edited by CAAD4
Selling for R3500.
Is that really a KTM?
  On 7/26/2013 at 6:19 AM, BBN said:
Done my number two's.........so to speak!
Second Lurcher SS Rigid....DONE! This time with fongkong carbon fork.
The question is: which will you ride more?
Mine will always be the Brooks, will probably sell the others.
Pretty good, thought it might not be as stiff and might get a bit of vibration under braking but all is good and it has a bit of give in it , so not too hard on the wrists.
WoW BBN those bikes look awesome !!!
I've just finished building my Jamis Exile Comp as a SS. I upgraded my current bike to a carbon Jamis.
Going to put it through its paces in tonight's CM.
  • I used an On One CT
  • Shimano Acera Crank ( could afford XT at the Mo)
  • Surely 18T rear Sprocket
  • 32T Chainring I thin Surely aswell got it from LBS
  • Shimano 9spd chain
Bike is pretty smooth and quiet.
http://i1110.photobucket.com/albums/h452/frango141/Jamisss_zpsf5269581.jpg
That is how a singlespeed should be built my friend, nice bike! Carved from stone like a luddite (with bits and bobs you can put together) and not bought at the store :clap:
Glad to see your ego is healthy and you put a non rigid fork in front .Nice bike
PIC'S PLEASE.
