Set myself a target to build a rat bike with stuff out of my garage (and from mates/lbs) that is safely rideable and spend under 100 ZA rondts ..... So far so good, spent about 75, still need chain, back brake outer, headset spacers. Have a chain just need to decide whether I try a magic gear or fit the chain tensioner I have.
Frame - my old TT frame, recently replaced with a carbon magafter
Bars - old Ritchey bars that have been shortened
Brake levers - from a failed road bike straight bar experiment
Seat - worn Merida seat off my MTB SSR
Crank - MTB crank that had the blades stripped off it
Front wheel - donated by LBS when they moved shop and were tossing some stuff
Rear wheel - built by my son when he was working at a bike shop during college holidays
Rear cog - bits out of a few stripped cassettes
Brake calipers - donated by LBS old Shimano 600
Tyres - from old spares in the roof
Tubes - repaired 2 previously punctured tubes that were lying around
  • Replies 2k
Nice project - will probably be one of your favourite bikes...
  On 7/24/2014 at 10:37 AM, Wil6 said:
Say hello to my new steel 29er frame, hopefully getting it next week :clap:
The only problem at this moment is if I'm going to run it rigid or not....
It is more comfortable to run it flaccid. :P
  On 7/24/2014 at 9:42 PM, Spoke101 said:
Does anyone know who owns this beast?
I dont know what to make of this.
but it does look like is has one of those internal hub gearing systems
I forget who, but someone posted it on thehub in its build stages.
GT Zaskar, custom dropouts, belt drive
After a visit to my LBS it's all done! Lekker to ride and pretty comfortable, will do just fine to run errands and visit the LBS with :) - SS and flat pedals are ideal to just jump on and go, no dancing shoes or helmet required ;)
Just missed Friday...
Funny comment about the dancing shoes! Now I will never be able to separate cycling and tap-dancing...
Decided to do a proper home made single speed
Emptied the bike room, garage and smokkelled a
Track frame from my LBS for a steal..
Started with sanding and Matt spraying the frame
Added the stock seat post and stem
Will convert a set of std road bars into bull horns
But until then a set of fixie bars will do..
I added a set of 1980...something Simano calipers
I am playing around with the rear sprockets
I took the 7 speed cassette apart and added
Spacers keeping 3 sprockets on for now ..
A 12 .. 17.. 23 .. Will decide later after busting my legs to chose a ratio...
Wheels are stock 1999 105 ..
I'm looking for a set of decent track hubs with a flip flop rear hub to build a decent set of deep dish wheels ....
Current cost is minimal as all bits bar the track frame were off previous builds ...
Tyres will be on tomorrow
Edited by MTB0007
