Ok...so that was the shortest i have ever owned a bike. My business partner saw it and took it.
Luckily i had ordered a spare bike for just such an eventuallity.
And thanks to a late friday delivery of some american classic race wheels, i had two singlespeend monsters delivered in a day.
Not a bad friday.
Damn thats pretty. Hows that clearance of those tyres? from the looks of it there is about 10mm between the tyre and arch of the fork.
  • Replies 2k
Not a bad friday.
Have almost the exact same bike, except has gears and the AMC race wheels.... If I decide to sell my On One SS then it will def become a SS
This is a project Ive recently completed for a friend...
Would be cool to hear what you guys think, Ive replaced the chain,seat, tires , serviced the hub with bearings, polished the heck out of the frame and brought the chrome wheels and handlebar back to life.
Cool fiets!
Sit reflectors ook op die fiets. Witte voor en rooie agter. Sal netjies lyk
Not a bad friday.
Wayne, another beauty for you. I like it
Not a bad friday.
I can't stop looking at this bike. That niner has such killer lines! And those tyres. I'm so jealous!
Please help this stupid...
I'm re-doing that 1950's Raleigh roadster. I want to keep the front cog- standard with the Raleigh heron and 48 teeth.
The back cog is 18, which is a ratio of 1:2.6. Is that more or less standard for SS?
Forget about gear ratios. This is a classic. Keep it as it came from the factory. My 2c
I definitely don't want to change anything more (already had to re-paint due to a proper horrible home paint job on it), but I also want to ride it and not die doing the mountains around here, + it weighs what feels like a half-ton.
Just wondered what is a "standard" ratio on SS.
Standard is what's comfortable for the rider. Some people like to suffer, others like to take it easy. Average is just a number in between.
  • 2 weeks later...
Totally SS clueless so excuse.
I have a 2009 Cannondale Prophet in Bare alu. Replaced it with a new Anthem SX. So I can sell it for R5000 if I am lucky, however was thinking with the lefty and really good brakes and new rear shock why not make it a SS for some trail riding. The problem with the Prophet has always been the front chainring setup, as it has a wider than standard BB so a single chainring front will relieve many of the problems.
Q: Can you make a Dual bike a SS with the rear suspension pivot vs chain tension?
     What ratios do I use? Or is this a trial and error thing.
this is something i put together to work out gears etc on an SS with diff wheel size options. makes it a bit easier if you have a more than one SS with diff wheel sizes
Also see Bike Gear Calculator App.
Yes you can - you can get a 'sprung' tensioner. This way the although the chain needs to be long enough to accommodate the frames most 'suspended' point it will still be tensioned across the travel range. Not sure how well they work though. I'd run a front chain guide too if it was my setup - just to try and counter any chain whip/ bounce on the trails.
I good ratio to start with is 2:1. 32:16 on a 26". If you haven't SSed before maybe start with 32:18.
Edited by Ryanpmb
