I will be finally getting my new 2012 Shimano XT Brake set this week :clap: The rotors that are included are centre lock and I need 6 Bolt. I know there are the Ice Tech rotors that you can get but they are pretty expensive, but they do recommend them for the new Shimano Brake sets.
I have the Alligator wind cutters on my other bike, which go with a SLY brake set. I'm not too keen on them as I find the calipers don't "grip" the rotors nicely because of the outside shape of the widcutter and thus results in the brakes shuddering.
So do I stick with the Alligator Brand but rather go with the Wavy rotor or the Pizza Cutter? Even willing to try the Shimano 6 Bolt. Any suggestions would be greatly appreciated, and especially from any folks running the 2012 XT brakes.
  • Replies 32
I've never used Shimano brakes, but when i changed from Alligator Windcutters to Original Hope Floating rotors it was noticeable. I'd say stay with original. Can't the supplier supply 6 bolt instead of CL?
I changed from the original Tektro disc to the Aligator Windcutter, the braking was OK but I found the disc warped easily. Went and bought a normal Shimano disc and its far better and that was just a bottom of the range disc (cost me about R220 for a 180 six bolt)
+1 for Hope Floating Rotors...
I run 203mm Hope Saw Floating Rotors on my DH bike
(sorry about the bad quality of the pic)
Edited by patches
Ive only just realised they come in the set as CL, they have been sent already, so I will sell the Centre locks and get 6 bolt if need be. So running the HOPE rotors with Shimano should be OK? :unsure:
Edited by Caerus
You can get a 6-bolt adapter for the centre-lock rotors if you want... Those XT discs seem to be pretty sturdy. Far sturdier than the Alligators, imo...
I have seen the adapters, If I can avoid them by selling off the CL rotors and getting something else I would prefer that. Little bit weary of the whole adapter route.
I would guess so, but what I actually meant is stick with what they should be i.e. Hope with Hope and Shimano with Shimano.
OK, that makes sense ;)
You will need something like this to fit 6-bolt discs to centre-lock hubs. Sorry, have no idea where to get one.
http://www.aboveandbeyondsports.com/media/03/a20791d130f742acb1f494_m.JPG
Always dubious of going this route, would prefer to get just six bolt without any adapters
Take em still packaged to your bike store and swap em for 6 Bolt.
Personally I can't imagine the 6-bolt->cl converter to be any less affective... the shimano disc rotors are very sturdy and should not warp so easily as conventional 6-bolt rotors.
