I have some Easton mountain bike wheels that need the bearings serviced. What is the general consensus on the correct grease to use??
I just use normal bearing grease...got a tub at builders and i am sure it will last me years. Some guys like marine grease...i couldn't be bothered
I have been using a tub of Lithium grease for the past few years. Bearings get repacked every 6 or so months. Sometimes I leave them for a year. Have not had any failures yet. Biggest thing is to make sure the seals are in good order and NEVER direct a jet of water any where near them.
Yea also do repack of grease every now and again...BB and hubs(citec's and hope's)...the wheels are almost always prestine. the bb's sometimes need a fresh dose
Also good - Yamalube Blue Wtaerproof grease avail at any Yamaha Dealer, around R70 500g.
If you going to the effort of servicing yourself you may as well use decent preferably waterproof stuff, may just be that little bit of extra protection that prevents issues out on the trails.
Edited by Skylark
Isn't all grease waterproof or have waterproofing properties? Hence the reason we use it to keep moisture out of areas with bearings.....serious question.
I guess "waterproof" grease will not form an emulsion when mixed with water...? and others might?
Ah ok...not that I have seen any emulsified grease...its normally contaminated by grit and sand....
