Bottom Bracket clicking noise
inthesaddle
have a scott spark 920 7 months old - has developed a clicking noise from bb - which is in time with pedal rotation - stop pedalling no noise - have removed cranks and checked bb for play still tight
I dont want to remove bb if not neccessary - anybody had similar prob and resolved it
Check pedals, rear skewer, before bb. Can be loose suspension bolts too. All clicking under load, so will seem like the same part of pedal revolution.
its not the BB
its grit on your seatpost when the seat tube flexes under load of pedaling your hear a tick tick sound ..
take out seatpost clean it clean the collar of the seat tube clean the seat clamp
bit of grease replace
noise gone
common noise complaint / most common solution
You are on a magical mystery tour, it could be any of the above or none of the above. As a general rule if the clicking goes away after you wash your bike it's not the bottom bracket and pivot points or any junction that has load placed on it with a pedal stroke could be the problem. My last mystery was the bolt connecting my rear dérailleur hanger to the frame, the fix was a simple clean out of the dust trapped in it and a bit of grease. This was a recurring problem so remember the noise carefully once you solve it.
Also had a clicking sound recently. I tried everything, eventually I swallowed my pride and took it to a bike shop. They diagnosed a loose bb. First ride when it came back. The clicking was there. That night I woke up with an epiphany. Ran to my bike turned it over and there was the problem. My seat had cracked. Don't think because it sounds like the bb that it is the bb
Hey OP. Got exactly the same problem now. I can feel the vibrations of the clicking through my right foot.
BB was opened by lbs. Nothing wrong. Will check pivots tomorrow.
Just hate it when my bike sounds like a makro special.
Clicking BB can be any of the following (had the same problem a while ago, my issue was no was first item)
Qr skewer moving inside hub and moving around (rear)
Seatpost clamp
Saddle rails
Pedal axles
Cleat & pedal contact area
Headset
Stem, headset, handlebar contacts
Crank arm bolts
Chain ring bolts
Seatpost clamp
Saddle rails
Pedal axles
Headset
Crank arm bolts
Chain ring bolts
Perhaps we should just add to your list:
Rear derailleur bolt
Rear derailleur hanger bolt
add heaven forbid:
Cracked frame
Cracked swingarm,
I had a terrible clicking sound on my bike a few years ago. After checking just about every part, it turned out to be a fairly new pedal which was not securely tightened. Some copperslip and a pedal wrench solved the problem.
Loose mtb cleats can also make a clicking sound so check your shoes as well.
