A vertical shock is better...
Serious Panda
  • Replies 185
A modern design would have the shock mounted vertically with the seat tube.
And not have that rear pivot.
Bahahahahahaha!
And again, cos it seems as if someone needs to say this at least once a month. Suspension design is far more than just shock positioning.
Pivot placement. Shock tune. Linkages. Leverage ratios. Etc etc.
There's a reason that the Horst Link is one of the most popular suspension designs now that the spaz patent has run out.
Yes, some iterations needed a lockout to prevent Bob when pedalling. But the latest ones are mostly fine, just needing a firmer shock tune (thats the reason for the brain, btw. An almost automatic "climb" setting that has a blow-off valve that allows it to open on hits above a certain threshold)
Scott was almost the last ones to realise that pivot placement was crucial, and that was a single pivot, not a Horst Link like the spaz.
Seriously. Read up on it before you comment...
Nothing "modern" about that design at all.... it has been around for years.... try again...
Reasoning for the change in Scott shock positioning:
Better to drive suspension forces in to bb area where frame is naturally stiffer
Weigh distribution - lower COG
"Allowed them to tune progression curve more reliably"
1 of those is BS. I'll give a hint. The YT TUES is one of the most "progressive" suspension designs on the market.
Another one is also semi BS, just marketed a little better. The spaz frame design is an x wing and is very stiff at the shock mount position. Previous Scott design drove the shock forces almost directly into the top tube horizontally though, without any additional bracing and was therefore exposed to longitudinal compression forces (not good on a carbon tube)
Bahahahahahaha!
Baaah baah naah naah baaah.
Yes true its been around. I am comparing this to the modern design of the award winning Silverback Sesta. Vertical shock to remove the need for a re-enforced top tube and a solid rear triangle.
Very stiff design, sure. And I knew you were referring to it earlier as well.
But not "the best". And certainly not rendering any other design inferior or "old"
To me it seems like a superior design scientifically/on paper.
I do not see the woo. Less pivots is better, a solid rear triangle is better, and the shock at the seatpost is better.
Yet specialized are at the front of the pack in enduro , XC and downhill ......men and women
but no more pivots and seat tube mounted shocks are not the best  :whistling:
Yes they do have the best riders/most money.
None of which are empirically true. A vertical shock position is not demonstrably better than a horizontal one. Less pivots are not demonstrably better than more pivots. A solid rear triangle is not demonstrably better than one with pivot points in it.
There are trade-offs in each situation, and the more you investigate the more you realise that each suspension design is an exercise in compromises and the attempt to achieve an end result.
The Silverback had a very clear end result - pedalling performance and stiffness in the rear whilst still being active on the rough stuff. They could have utilized any number of combinations to achieve this end result:
A main pivot that locates higher on the seat tube / down tube than the top end of their "ideal" chainring size - this is the most common characteristic in modern suspension designs
Larger pivot bearings - also being used more frequently now
A firmer suspension tune
Solid rear triangle
Progressive shock curve
Horst link with a progressive shock tune
Single Pivot with a progressive shock tune
DW link (also has a solid rear triangle)
And and and.
The Silverback is a good design. But it is by no means "the best"
If you believe that, then you've drunk the kool-aid. Properly.
