XTR Pedals - keep on failing
JannievanZyl
This is my second set of XTR pedals that broke like this. Pretty much the end of your ride when this happens. Not very confidence inspiring. :(
Anyone else seeing this on these pedals and can it be repaired?
  • Replies 47
Most of the time shimanos are bombproof.
The saints have the same issues(axle breaking off) but the xtr's and xt's are flawless IMO
Contact the place you bought them at I'm dead sure can you can still claim a new set through warranty.
Good luck . Let us know what happend.
xtr have a known problem. Shimano do normally warranty them easily. they come with a 2 yr warranty. in future stick to xt
So take this opportunity and ask for a set of XT's
My trusty old 520s are probably the most bang for my buck bike part I have ever bought. Smash them in rocks all the time, never fail. Serviced them once in the last 3 years.
This.
No reason to get them unless you want to save grams in the last place you should. And even then replace them at least every 6 months. Cos they're a race pedal. Built to be replaced
How maney times are we going to have this thread resurrected .Buy XT only .In Europe the bikestores don,t even keep any XTR componant,s .It is considered for pro,s only !
The pro's ride XT.
Good enough for me
Saving 20g, but having something that breaks easily is plain stupid
The pro's ride XT.
Good enough for me
Pros don't buy, and probably have them swopped out after every race.
As said get XT only pedals
I saw an XTR crank arm that snapped just above where it bolts onto the shaft. Fairly new, under 6 months old, lady rider. I couldn't believe how thin the side walls of the casting was obviously to save on weight. Could result in a nasty injury if peddling hard.
OP did the shaft actually break or did the securing bolt at the end of the shaft come loose, allowing the pedal to disassemble itself?
If a loose bolt it can be fixed.
I have been using the same set of 540 for 12 years. I have serviced them 3 times (by myself) and there still going strong
