2008 Zipp WHICH 11-speed Campag body do I need
Flemish Lion
I'm having not much luck in the wanted section so here is hoping some hubbers can assist!
My wife (Jo VDW) recently upgraded to campy 11-speed.
She would like to use her 2008 Zipp 303s for SAs but the 182 hub (see pics) has a Shimano free body.
Which Campy free body will fit on this hub and where I can source one.
Google hasn't been of much help :(
I've asked Cape Cycle Systems and Cycletech but no luck.
I also have a similar pair of these wheels. I was told they cannot take an 11sp cassette.
It is possible to machine 1.6mm off the hub to accommodate the cassette you want, but I couldn't find anyone to do it for me
In think that is for Shimano only though ...
Sent from my LG-D958 using Tapatalk
  On 1/30/2018 at 6:36 AM, Madone69 said:
You need the blue coloured free body from Zipp to run Campy 10 or 11 speed - no problem.
Ask Cape Cycle System to source or go online
The problem is finding the Blue body for the 182 Zipp hub.
I found a 188 blue Campag freehub (2009 onwards) but I need a conversion kit to fit it on my 182 hub :(
We've been in contact with Cape Cycle Systems...
  On 1/31/2018 at 8:34 AM, Underachiever said:
Would support that.  I ran my 11 spd Chorus Cassette on my 2005 Eurus with no problem.
Yes... but I have a red Shimano free body which needs to be replaced by the blue Campag body :(
You can also machine the 182 Shimano freebody down to fit a 11 Shimano cassette
I did it in the past and worked 100%
Shimano 11 speed cassette will also work with 11 campy
Not ideal, but a cheap solution...
take 1.8mm off here
take 1.8mm off here
Aha... Google confirms 11-speed groupos can be mixed up without any issues.
It would however mean I cannot use the Zipp 303s anymore so probably won't do it as she we are looking at new race wheels for her but not before SAs :(
If you don't want to machine down the free body, just get a 11 speed Shimano cassette and machine the inside of the cassette to fit the 10 speed free body. A friend of mine did it and it worked like a charm.
Een boer maak een plan in die Vrystaat ;)!
Let's see if I can get my hands on a 11-speed cassette.
What ratio you want?
11/25 work?
