Wider road tires
platvis
  • Replies 40
I went to a 25mm and I'm enjoying it. To my knowledge the 28mm are more popular for terrain similar to cobbles? I could be mistaken though. You might also need to check frame clearance
Depends as well what your inner rim diameter is. If you fit a wider tyre on a rim with narrow inner dimension it will have a mushroom effect. The wider the inner measurement the better a wider tyre will seat. Attached is the ERTO sizing chart.
Running Schwalbe Pro Ones in the 25mm size on American Classic 30s, installed on the rim they actually measure out to be 27mm, rides very comfortably. Had to open up the brakes to clear the tyres but not other adjustments needed.
Go for it
Go for it
Yep, I've also got 25mm tyres on American Classic Argents, which come out to just under 28mm. Super plush ride.
Tp get the real value of the wider tyre, drop your tyre pressure. I'm running 28mm tyres @ 6 Bar - 80 kg. It is comfy and grippy.
True. I used to run my 23mm tyres at 7+ Bar, being 94kg dry wieght.
With the 25mm(27mm on the rim) I run them at 5Bar and they are smooth.
Same setup here, 25mm Gp4000SIIs on Argents. It feels great, but on my 2008 Merida frame the rear tyre is a prayer away from touching the frame.
As mentioned, do your homework on fit. I would assume that your LBS would be prepared to fit the tyres to your bike to see if they work and remove if not.
As an example, I've been running 28 Conti Gatorskins for 2 years. Recently picked up 28 Conti GP4000s tyres. Was surprised to find the GPS4000s don't fit my fork, which is rated to accept 28s.
Measured with a vernier caliper, the Gatorskin 28s in fact measure around 27mm while the GP4000s are 30mm on the same rim.
I made the switch from 23mm to 25mm last season and will never ever look back.
Front fork clearance is just about enough with some extra space at the rear. Actually thinking about going 28mm rear and 25mm front just out of curiosity...
