Keep Q20 as far away from any bicycle as you can.
Just wipe them down with a cotton cloth (old T-shirt)
Buy some silicon spray (Spanjaard) and lightly coat.
(Q20 is not a lubricant)
No never q20
Brunox or WPL stanchion lube
This, brunox supension deo or similar, liike muc off, sram butter,  Dont use other oils
Edited by Eddy Gordo
Click on the link in my profile there you'll find a video on how to use Brunox
As said above after a cycle or two of your fork, dropper or shock the rest should all be wiped away, otherwise it'll create a funky mess on the seal on your next ride
**Stanchion lube IS NOT a replacement for regular maintenance, if the fork is thrashed inside spraying lube on the outside will do nothing
The 'lube' is more for keeping the seal supple and soft than it is for actual lubrication
No never q20
Where can one get WPL?  I haven't been able to find it locally...?
Like happiness, fork lubrication comes from within.
Service your fork regularly and you won't need to lubricate anything from the outside.
That said, something like Brunox Fork Deo, Veyga Wet Scream, Finish Line stanchion lube or just plain old fork oil can help reduce initial stiction after you've washed your bike. As said above, stay away from aerosols and all purpose oils as they often have additives including chlorine that will swell or attack the rubber in your fork seals.
Super hard to get here
Limited suppliers and resellers
Best is to import on your own and that's even harder with the current global situation
Just get some fine grade wet n' dry and buff those stanchions up a beauty.
kidding... obviously. Please don't do this. Not that I thought you would. But if you did...
I took your advice and now my fork is ruined.
I couldn't see your disclaimer at the bottom due to poor eyesight.
You are not a good person.
