If you've ever struggled with pushing in brake pistons this seems like a very useful tool. Birzman dual Disc Brake Piston Pusher:
ngcb4
And it should be easy enough to make a budget / diy version:
Wonder why we don't see more of these instead of the usual pad spreader tools. It would have come in handy for myself recently.
  On 11/21/2020 at 9:31 AM, BMXER said:
What's wrong with a 13mm spanner and a strong hand? A square push and the pistons go back.
Usually that works, but sometimes you have a very sticky piston like I recently experienced and that trick didn't work.
I think this kind of tool would be nice for workshops.
Edited by MrJacques
The Birzman one is designed that you could use it without removing the caliper / wheel from the frame, like when you change brake pads.
