13 minutes ago, splat said:
You are right. I am too heavy for them.
I suppose that I was hoping that the MK4's would be a bit more robust as I was considering them for a gravel bike build with some Hope RS4 hubs.
They are no longer on my radar
How much heavier is the arch ? I assume it'll handle you just fine.
  • Replies 48
There are quite a few rims I'd rather put on a gravel bike, if Crests aren't your cup of tea.
For one thing, many gravel bikes are more road focused, and you may want to use the 24h hubs that come with them.
In this case, opt for the DT Swiss GR531 - heavier than the Crests but rock solid.
  • 2 months later...
Has anybody been riding the Crest mk4's long enough to comment on rigidity and durability?
My 11 month old rear mk3 is like spaghetti with 9 cracked nipples and need to decide if I should pay in for warranty replacement and upgrade (but will either have to replace front at full price or ride mis-matched wheels).
  • 4 months later...
It's almost been a year on from the launch of the new rims.
Has anyone got some experience to say whether these new generations rims are better than the previous generation? Have they fixed the cracked nipple issue?
I've been running the MK4 crests for about 6 months and they seem to be holding up at the moment. All the sets of MK3 crest rims that I had started to crack on the rear by now.
  • 1 year later...
Not a single instance of a crack at the spoke holes, that I'm aware of, since the Mk4 range was launched.
Safe to say they've solved the problem.
Also, from my perspective, they're one of the only brands who have a healthy rim stock-holding in SA in all 3 versions (Crest, Arch & Flow) in 28 and 32h versions.
I'm busy with an article now explaining their rim range with specs, weights and recommended use cases.
Seriously one of the best alloy rim options on the market right now.
I'll post a link to the article here once I'm done writing it later today.
  • 7 months later...
23 minutes ago, 26er said:
Just an update,my Crest mk4’s have cracked , Submitting a warranty claim through LBS.
Can you share some pics?
