Hi guys. So recently I've purchased a dual suspension bike. Coming from a couple of hardtails I'm kinda lost on how the rear shock travel works.
I've noticed on the shock the eye to eye travel is 190x 45mm stroke but how do I figure out howmuch travel that is in total for example is it 120mm or 110mm etc
I'm currently riding a 2019 Norco Optic and was wanting to get more shock travel out of it. Is it possible or not??
Thanks in advance
Thanks in advance
You would need to let all the air out of the shock and fully compress the rear suspension to see how much clearance you have between tire and seattube and potentially linkage and frame. Even if you can overstroke it by a few mm, the manufacturer gave it a specific amount of travel for a reason.
If you need more travel, then you should consider a more aggressive longer travel bike, as squeezing more travel out of a frame has its disadvantages for sure.
As Mtbrider said, Will have to check, only way to increase, even if there was space, would to go find a shock with the same eye to eye, but with more stroke.
This still isn’t ideal, best would be to upgrade frame.
rear travel is down to leverage ratio not expose stroke or stanchion.
50mm stroke can result in in 100mm travel with 2 leverage ratio or 3 with appropriate ratio
Okay so how do I find out the leverage ratio of the bike I have is or is it not that simple? Sorry it's just so confusing to me
That would definitely be on the cards but not immediately.
I was saying if he wants to increase travel, he must increase stroke...
As there is no way to easily change your leverage ratio (at least to my knowledge)
It's 110 mm 29er and 120mm 650b
And you can never use all the travel unless the Shock is PAP
Specs
Rear ShockFox Float DPS Factory, 190x50.8mm, EVOL/Kashima Coating
Divide your shock stroke by the bike travel
Ie. 50mm shock stroke and bike with 150mm travel
ratio is 3
Specs
Wait what?
If you're NOT using all your travel your setup is wrong.
If you can't bottom your travel out then you need to fix something.
ratio is 3
In simple terms, that means that for every 1mm you increase the shock stroke, you wil gain 3mm more rear travel.
7 minutes ago, Jewbacca said:
Wait what?
Nice jokes😂
measure suspension travel in a work stand. Deflate the shock, take a tape measure and hold it next the the rear wheel axle. Lift the wheel till the shock reaches its bump stop . What point on the tape measure does the axle stop?
100mm? Then 100mm travel.
divide that number by the shock stroke length and you have leverage ratio.
you shouldn’t bottom out your shock ever unless you got some thing horribly wrong. Using the bull stops is not desirable
10 minutes ago, DieselnDust said:
Nice jokes😂
Thanks for this advice I Will try and do so now to see howmuch rear travel the the shock realistically has.
I didn't bottom the shock out I bought the bike under the impression that it has 120mm travel but now I want to see if it is true and was asking how to do so and if the Frame can compensate for more travel or not
28 minutes ago, DieselnDust said:
Nice jokes😂
https://bikerumor.com/suspension-setup-series-6-how-often-should-i-bottom-out/#:~:text=“You should bottom out a,braking holes entering a turn.
https://mtbfunplanet.com/bottom-out-a-mountain-bike-suspension-is-it-bad/
Some of these pro's would disagree with you.
Edited by Jewbacca
