Rear end of bike making clicking sound - I need help diagnosing what may be causing it
Is the hub also only 1 month old? I had the bearing in a freehub fail and it only made the noise when actually pedaling. I was convinced it was the seat post until I realized it made the same horrible noise when standing or seated while pedaling.
  • Replies 81
Yip it is only a month old. I am convinced it is the bearing. I am definitely considering buying some reslly high quality bearings that will last. It makes the noise when standing and the bearing feels gritty.
1 hour ago, MTBRIDER1234 said:
Hey hubbers, I was out riding yesterday and upon riding home, I discovered there was a clicking sound coming from the rear end.
I suspect it is hub-related because I have recently regreased the entire bottom bracket assembly and the noise is only present when I am pedalling.
Even if I pedal with literally no load, the clicking is still present, but only if I am sitting on the bike. On the stand, the noise is gone.
Another thing that has confused me is that it only makes the noise in the 3 easiest gears.
Incase it helps, it is a sram gx 10-50 cassette on a lyne amp high engagement wheel.
Normally I am pretty good with these things but this has stumped me. I am planning to tear the hub down on saturday but I am hoping it may be something simple that I overlooked.
Freehub. Open and clean out all the grease. Grease only the springs with a light grease.
Test again.
Edited by Steady Spin
I am actually not sure, the cassette is pretty dead, so there may well be. But it isn't a sound from the chain skipping or anything, it is a click that you can feel through the bike.
Mine was just a sound, not a "feel".
Reading the rest of your posts I cant help but thinking back to a "sound" we had on Maritz's bike ....  Turned out the pedal bearings were shot.  Just about did a strip down and rebuild before tracing it back to the source.
These sounds can really chase one in circles ....
Is that one month with or without Around the Pot ..... :P
Sorry bud
The standard bearings are rubbish. I need another replacement again. Lasted 8 months.
Did you remove the freehub at any stage ?
Could be a pawl flopping about.
 Could be a bearing
could be a slight misalignment of the derailleur
could be a pivot bearing
check the crank retaining bolt torque. SRAM bb30 cranks have a habit of working the bolt lose if you don’t apply a drop of loctite
On my Trek Fuel EX5 the bearing collapsed after a 1 000 km, of basic trails with no water or mud.
Trek actually wanted to sell me a new hub !!  On a bike which had only done 1 000 km.
Was hoping it was a once of issue .... but seems I am not only person having issues with their bearings.
 Could be a bearing
Thanks Diesel, you are always a help on any mechanical thread.
I have not removed the freehub, so the pawls should be fine, but I will see when I open it.
The cranks are lyne and I recently regreased them and checked torque so they are all good.
I think it's the bearings but I will see later this week.
I think I may just spend the money and buy some nice bearings if they are what is causing it. I understand companies have to keep the cost down to sell things at a budget price and bearings are easy to replace.
I could also feel the click. Replaced bearings and it persisted. Ended with replacing the freehub itself. Same hub.
