Recently got Rival AXS shifters/brakes on my bike, and looking to add the required brake bleed tooling to my arsenal.
Any recommendations on a good bleed kit available locally?
Currently leaning towards something like this: https://evobikes.co.za/product/jagwire-wst052-elite-dot-bleed-kit/
Seems like a lot, but when you factor in ~R150 per brake at the LBS it starts to pay for itself quite quickly.
Thoughts?
  On 4/4/2023 at 7:00 AM, thebob said:
Have the same kit for Shimano usage. Worth the price of admission
Expand
How often do you bleed brakes ?
Honestly for my road bike and MTB I just have the shimano funnel and some aquarium hose and I gravity bleed them easily, right of admission < a full bleed at your local shop.
For the gravel bike (and my other bikes with SRAM before then), I just take it to the shop whenever the brakes feel crap (which is unfortunately more often on the SRAM I've had than on the shimano).
Expand
I do mine every 6 months at minimum. I've also found having the correct tools for the job makes things so much easier.
If the same kit works on both bikes Shimano and Sram I guess it's worth it if you have 2 or 3 bikes to look after (or more if you have a family of cyclists)... You now make me consider it 🤣
If you have SRAM brakes on any of your other bikes, or you have mates who do, drop the cash and get the SRAM Pro kit. It's about half a million bucks, but so much better than any of the generics that it's worth it.
Also, I've had mine in use in a shop for 10 years and it's still going strong - I've only had to swap the hoses out once in that time, and it was a 10 minute job with a roll of vinyl hose I got from a plastics company.
Expand
Has SRAM swapped over from DOT fluid to Mineral fluid?
I'm loath to cross pollinate bleed kits between the two, but I guess a good thorough clean after use would suffice.
I have a  mineral fluid kit with multiple hoses and attachments and a DOT fluid kit with the same. Also both of them are so old they are probably teenagers and have a tiktok account.
Sram has made a cheap looking guide replacement that's called the DB8
that's the only brake made by SRAM that uses mineral oil
ALL other SRAM brakes use Dot fluid
  On 4/4/2023 at 3:47 PM, Furbz said:
Are the latest Sram still dot?
 Whoever decided to use a paint corrosive fluid in Sram brakes needs to get the ears boxed.
Expand
Mon Dieu 😮
According to the 'neo' hub experts and anoraks ANYTHING SRAM is the best thing since sliced bread!
Expand
My LBS quotes R250 per brake, so I'd assume a 3 year payback (inflation notwithstanding) even if I only have 1 SRAM bike and only bleed once a year.
Edited by MongooseMan
