Hi,
What is the easiest way to top-up the sealant of your tubeless setup? Just deflate, pop out the bead, and pour in some more? Do you have to do the whole soap-and-water thing afterwards again etc?
Any quick fixes?
Hi,
Any quick fixes?
Not the cheapest, but I recon the easiest is to buy two small bottels of Stans and undo the vavle,empty the bottle , replace valve and inflate,that way the tyre was not un-done from the rim and inflating should not be a problem.
Deflate tyre slowly. Remove valve core. Take a plastic syringe and fill up with sealant. Place syringe in end of valve stem and refill. Replace stem core and inflate.
Easy
+1
Yes, the way to go
No
  • 1 year later...
I know this was an old topic of discussion, but did a search yesterday and came to this one......and exacly what i was looking for. Thank you to everybody comments here that made a job that i dreaded to do so simple and easy. Thank you again!
Get a 15 gauge needle and 20ml syringe, suck the sealant up through the needle, then you know it'll go back through, jab it through the tyre tread, inject and spin. This way you don't even need to deflate. Look for a duiweltjie hole, and you won't even be putting a new hole in your tyre. :devil:
I've only done this when I'm feeling very lazy or am in a hurry.
Hi,
Any quick fixes?
Yes
Deflate
Open side of tyre
Pour in juice
Close tyre
Bomb till it pops
Ride
2-3 mins
I like this way even better!!
Every 3 to 5 months I give my wheels a sealant - service. Remove the tyre, loose the old sealant, clean the rims and tyres, add new fresh sealant and off I go. The only way I get proper peace of mind. Works for me!
