Hey guys I'm in the market for a new pump an was wondering what is the best price decent pump to go for for a presta valve mtb? Do I use a pump or do I go co2 bombs. Thanks in advance guys.
  • Replies 57
A Pomp is a Pomp ou Pel
Nooit!
Dont believe it.
I got a Giant pomp from SW, and it worked exactly once...
But apart from quality, I found a pomp that has worked flawlessly since I got it, and is wider so has a bigger volume for less pomping of big MTB tires.
Only about R500, and I use it before I ride.
Bombs I take with for on the ride.
Get a converter for your presta valves to shraeder. The presta valves are going to bend and break at some stage if you use a hand pump.
co2 bombs are great to have as a backup carry atleast 2. Especially if you have tubeless wheels. But you still need a good pump in your camelback as well!
The pic:
Now, that I'd like to see,
@OP, specify, one to carry with you on the bike, or a floor pump for home use?
Had a cheap Giant one, had a more expensive Topeak one, both were crap. Topeak one is laying in the veld somewhere in the Magalies area after it became airborne...!
Now I just ride with 3 bombs. Then again I have those thornproof tubes and tyre liners and never (touch wood) get a puncture.
i have 2 floor pumps for home use and carry 1 small bike pump and 2 bombs when out cycling.
Quick sales pitch, in Ride Mag i see for 94.7 expo Solomons are selling 10 16g bombs for R100.
Edited by scotty
There are only 4 pumps you should be looking at:
Lezyne CNC floor drive - for roadies http://www.lezyne.co...CNC-Floor-Drive
Lezyne CNC dirt drive - for MTBers http://www.lezyne.co...irt-Floor-Drive
Lezyne AlloyDrive - for MTB http://www.lezyne.com/products/hand-pumps/high-volume#!Alloy-Drive
Lezyne Carbon Drive - for road http://www.lezyne.co...RBON-ROAD-DRIVE
If you like bombs then get:
Lezyne Road Drive CFH - road pump with bombs http://www.lezyne.co...!road-drive-cfh
Lezyne CFH Alloy Drive - MTB pump with bombs http://www.lezyne.co...ALLOY-DRIVE-CFH
Wasting your time looking at anything else.
Edited by CarbonDual29er
Guest Travis.
Lezyne Alloy Drive pump - best carry-on pump I've used. It's very easy to use and works 100% every time!
