Sbloomer Posted January 20, 2014 Share I'm getting back into cycling but have been starting to go to gym to do some cardio. I've been inactive for some time because of the need for bilateral THR. I'm 42 and the (discredited it seems) max heart rate for me is 178. Now, the last couple of times I've been at spinning classes, my average HR has been around 156, with my max around 181. Even at 181 it doesn't feel like i'm going to fall over and die. At the end of the session I feel tired, but good. Now several articles suggest not exceeding 85% Max HR for any length of time, with statement like it hurts your recovery. But if i stick to less than 85% sometimes I feel I haven't done anything worthwhile. Should I be worried and tone it down? Get to a doc to see what my real max HR is? My resting HR is about 70-75 at the moment FWIW. Thanks! Link to comment Share on other sites More sharing options...
V12man Posted January 20, 2014 Share Max heart rates are very individualised - and the calculation is just a guideline - the only way to determine it with any level of accuracy is to specifically test to find out what it is. If you have been inactive for several years, at your age you should have a cadiac stress test done by a cardiologist, before engaging in too strenuous an exercise program. And while you are getting checked up - assuming you are a male - get your prostate tested too... it's a blood test.. Edited January 20, 2014 by V12man Pants Boy 1 Link to comment Share on other sites More sharing options...
SwissVan Posted January 20, 2014 Share I'm getting back into cycling but have been starting to go to gym to do some cardio. I've been inactive for some time because of the need for bilateral THR. I'm 42 and the (discredited it seems) max heart rate for me is 178. Now, the last couple of times I've been at spinning classes, my average HR has been around 156, with my max around 181. Even at 181 it doesn't feel like i'm going to fall over and die. At the end of the session I feel tired, but good. Now several articles suggest not exceeding 85% Max HR for any length of time, with statement like it hurts your recovery. But if i stick to less than 85% sometimes I feel I haven't done anything worthwhile. Should I be worried and tone it down? Get to a doc to see what my real max HR is? My resting HR is about 70-75 at the moment FWIW. Thanks! Formulas for calculating Max HR are not always accurate and in some cases not even close.Yours sounds like one of those cases where its not close. You can do your own Max HR test quite easy, either on an In Door Trainer or riding on the road. EDIT: Don't do this unless you know 100% you are capable of handling the stress, you don't want to die or injure yourself. You will need a HR monitor that can record your max pulse and a long steady hill that you can ride for at least about 5 - 10 minutes without having to stop or go downhill. < Warm up at least 15 - 20 minutes.< Do 3 - 4 hard 2 minute efforts with 1 minute recovery in between, these are just to get you really warmed up.< Within 1 minute of the last hard effort proceed up the hill at a good pace (+/- 75% of full speed)< Stay seated and Increase your speed slightly every minute until you REALLY cannot increase the speed any more, THEN stand and sprint as hard as you can until you see black spots or feel like your going to be sick OR for about 10 - 20 seconds...you should not be able to carry on cycling without stopping for a rest or free wheeling.< Check your pulse monitor for the Max HR reading it recorded, this should be much closer to your real Max HR..... EDIT: and then add another 3 bpm to the recorded max. If you do this on an IDT (i.e. no hill) then you start at a high resistance and increase your speed every minute using your gears and or resistance setting, don't do it to quickly or increase the resistance to much as you want to take about 5 - 10 minutes to gradually increase your HR before making the final max sprint. Or you could save yourself the pain and use your lactic threshold (LTH) or functional threshold power (FTP) to calculate training zones, google it Everyone should do one Max HR test in their sporting life Edited January 22, 2014 by SwissVan Robodog 1 Link to comment Share on other sites More sharing options...
HappyMartin Posted January 20, 2014 Share I'm 53. My heart rate hit 203 on three occasions at the last 94.7. I still got dropped. Firemeister and Pants Boy 2 Link to comment Share on other sites More sharing options...
nuge Posted January 20, 2014 Share Max heart rates are very individualised - and the calculation is just a guideline - the only way to determine it with any level of accuracy is to specifically test to find out what it is. If you have been inactive for several years, at your age you should have a cadiac stress test done by a cardiologist, before engaging in too strenuous an exercise program. And while you are getting checked up - assuming you are a male - get your prostate tested too... it's a blood test.. what he said - great advice there Link to comment Share on other sites More sharing options...
Andymann Posted January 22, 2014 Share LOL - just ask the good Dr. on the left Link to comment Share on other sites More sharing options...
T-Bob Posted January 22, 2014 Share I've yet to do a full on Max Test but i've been going on the upper levels I've hit in training (not racing) which is around the 192 mark. I'd say that is probablly 90% to be honest as I've yet to do the 'get as far as you can THEN stand and sprint until you're going to be sick / black out / die / implode and explode all at once'. Just been as far as metal taste in mouth, pounding heartbeat in in head, mass pain, can't talk really - Need to apply Rule 5 and get out of the saddle. Link to comment Share on other sites More sharing options...
SwissVan Posted January 22, 2014 Share I've yet to do a full on Max Test but i've been going on the upper levels I've hit in training (not racing) which is around the 192 mark. I'd say that is probablly 90% to be honest as I've yet to do the 'get as far as you can THEN stand and sprint until you're going to be sick / black out / die / implode and explode all at once'. Just been as far as metal taste in mouth, pounding heartbeat in in head, mass pain, can't talk really - Need to apply Rule 5 and get out of the saddle. Ahhhh its not max HR unless you done the test.... Actually when doing a Max HR test some coaches recommend adding another a few more (+/-3) bpm to the recorded max, because most of us start slowing down before they reach 100%, survival instinct kicks in via the "Central Governor"... T-Bob 1 Link to comment Share on other sites More sharing options...
BarHugger Posted January 22, 2014 Share If some of you are interested in doing a max test (VO2, lactate, HRmax, etc.) and also muscle strength testing of quads and hammies (electronically) in a controlled environment (lab), send/pop/throw me a PM with your contact details and what you specifically want. Based in Pretoria so can accomodate from surrounding areas. PS: Steak on your back with hungry Rottie chasing will also help in determining max HR. T-Bob, Woofie and Pants Boy 3 Link to comment Share on other sites More sharing options...
Barend de Arend Posted January 22, 2014 Share Ahhhh its not max HR unless you done the test.... Actually when doing a Max HR test some coaches recommend adding another a few more (+/-3) bpm to the recorded max, because most of us start slowing down before they reach 100%, survival instinct kicks in via the "Central Governor"... That's why Friel recommends putting a gun to your head, or letting a lion loose immediately after doing the normal max hr test. Then you get your real max. Further notes:Max HR running != Max HR cycling. Do it on a bicycle.Do the test fresh. Don't do it the same week as a hard training session. SwissVan 1 Link to comment Share on other sites More sharing options...
Sbloomer Posted January 23, 2014 Share Thanks for the input everyone. Can anyone recommend a cardiologist I can go to in the Cape Town CBD or Table View areas, and how much a Max HR test is likely to cost? Edited January 23, 2014 by Sbloomer Link to comment Share on other sites More sharing options...
V12man Posted January 23, 2014 Share Thanks for the input everyone. Can anyone recommend a cardiologist I can go to in the Cape Town CBD or Table View areas, and how much a Max HR test is likely to cost? Wouter Basson - http://www.medpages.co.za/sf/index.php?page=person&personcode=25505 GREAT cardiologist.. and not too far from you - ignore the hype about his public profile - he is a brilliant clinician. He won't do the max HR test with you - you can do that on your own. BarHugger 1 Link to comment Share on other sites More sharing options...
carbon29er Posted January 23, 2014 Share EDIT: Don't do this unless you know 100% you are capable of handling the stress, you don't want to die or injure yourself. The human body will compensate by shutting down well before a self regulated stress test will cause death or injury. Our brain just won't let us carry on, which is why training without a program and plan never produces results. Link to comment Share on other sites More sharing options...
V12man Posted January 23, 2014 Share The human body will compensate by shutting down well before a self regulated stress test will cause death or injury. Our brain just won't let us carry on, which is why training without a program and plan never produces results. Ummm.... NO... there is a mortality associated with cardiac stress tests - and we never normally even take them close to a calculated max HR test. Don't attempt to do a max test unless you are sure you are capable - that's the bottom line. I do agree that training without a plan might not produce the results you want - but it is still better than not training. Link to comment Share on other sites More sharing options...
rouxtjie Posted January 23, 2014 Share Ummm.... NO... there is a mortality associated with cardiac stress tests - and we never normally even take them close to a calculated max HR test. Don't attempt to do a max test unless you are sure you are capable - that's the bottom line. I do agree that training without a plan might not produce the results you want - but it is still better than not training.or dying.... carbon29er 1 Link to comment Share on other sites More sharing options...
SwissVan Posted January 23, 2014 Share The human body will compensate by shutting down well before a self regulated stress test will cause death or injury. Our brain just won't let us carry on, which is why training without a program and plan never produces results. Agreed, but I was referring more to people who might have an abnormal or unknown medical condition such as heart disease, artery restriction..... You don't want to find out the hard way Link to comment Share on other sites More sharing options...
Register a new accountSign in
