How to ride my first race with a Power Meter
Spirog
Being a fatty, I end up isolated a lot. Then, you ride according to your FTP. Zone 4 and top of zone 3 is the sweet spot where you should be able to push for ages.
Otherwise, in a bunch just look at the wheel ahead, not your power number. You should be okay.
  • Replies 46
  On 9/10/2015 at 11:25 AM, Spirog said:
So, whay % of your FTP to do you aim to race at?
Still figuring this one out properly... With the power of the internet and some black magic, I worked out that my FTP was 296. But my normalized power at the end of a 2:30 race was 303w. So I am not sure if I have worked it out properly.
Pretty close - might be a bit low at 296 - maybe 10% low - close enough anyway.
MTB race power measurements vary a LOT - best to do a flat out 20m TT or use a trainer to determine this - a slight uphill seems to work best for doing it on the road - gravel roads deliver different numbers, so tar works most consistently.
Thanks a lot, I will give that a go. I had worked out FTP from my recent PPO test results.
  On 9/10/2015 at 12:11 PM, Donovan Le Cok said:
Sorry, should have specified. My power meter is on my MTB.
No "deciding" your pace in a road race.
On a MTB Race there simply is NO time to look at the power meter - especialy in single track and technical areas. PM is for training and post-race analysis only - and for that it is worth its weight in gold!
2:30 at 300W = :eek:
This is irrelavant.
The guys winning our local races are winning them with average power outputs of 210W-220W... This is lower than my last race average yet their FTP is so much higher.
This is because of shared work loads, percentage of responsibility, chasing breaks, not chasing breaks etc.
Racing with a power meter is only relevant if you need to pace yourself up a big climb. Or on a MTB where it is effectively a solo ride. Or is you want to go on a solo break away and need to know how to pace yourself.
Otherwise it is about the pace of the group.
Honestly, dont worry about power during races, focus on the wheels in front of you and the bunch movements. Use the power data retrospectively to adjust your training.
  On 9/10/2015 at 1:34 PM, Patchelicious said:
This is irrelavant.
This
Roadrace - don't lose the wheel!!
Where a powermeter will come in handy is following a solo victory after a breakaway with 80km to go. Those power stats should be loaded onto all and any form of social media  :thumbup:
