dev null Posted April 11, 2019 Share Which part exactly? This one? xt brake part.JPG if so i also broke this when removing it the 1st time but just assembled it exactly the same way & more than a year later it still works 100% No, the small part just below SALE in the following pic. Link to comment Share on other sites More sharing options...
MrJacques Posted April 11, 2019 Share No chance of 3d printing it? Link to comment Share on other sites More sharing options...
Captain Fastbastard Mayhem Posted April 11, 2019 Share No, the small part just below SALE in the following pic. brake-parts.jpgAll I see is a pic taken by a potato Link to comment Share on other sites More sharing options...
Meezo Posted April 11, 2019 Share All I see is a pic taken by a potatoMy bad, it was dark and lonely Link to comment Share on other sites More sharing options...
milky4130 Posted April 11, 2019 Share No, the small part just below SALE in the following pic. brake-parts.jpgah ok good luck then. Link to comment Share on other sites More sharing options...
dev null Posted April 11, 2019 Share BTW, if I was to say stuff it all and want to buy Hope brakes, which model would you suggest? Link to comment Share on other sites More sharing options...
CdT85 Posted December 3, 2019 Share Reviving an old thread here. Stripped out mate's stuck down M7000 SLX lever last night and found that the piston/plunger head is mushroomed. And seems that my M785 XTs isn't far from reaching that point also. Found these kits on Ali Xpress. Works out to about R190 with shipping if anyone want to attempt to rebuild/revive their lever. https://www.aliexpress.com/item/32973287602.html?spm=a2g0s.9042311.0.0.3c344c4d9QAbRL Lead time sux a bit, but will provide feedback on these and the rebuild process if and when they arrive one day Link to comment Share on other sites More sharing options...
Captain Fastbastard Mayhem Posted December 3, 2019 Share BTW, if I was to say stuff it all and want to buy Hope brakes, which model would you suggest?For you, race lever, X2 caliper. More than enough power and it's a slightly smaller package. EDIT: Yes, I know it's like 8 months later and all. Edited December 3, 2019 by Captain Fastbastard Mayhem Link to comment Share on other sites More sharing options...
babse Posted December 3, 2019 Share Found these kits on Ali Xpress. Works out to about R190 with shipping if anyone want to attempt to rebuild/revive their lever. https://www.aliexpress.com/item/32973287602.html?spm=a2g0s.9042311.0.0.3c344c4d9QAbRL Lead time sux a bit, but will provide feedback on these and the rebuild process if and when they arrive one daywonder if this will work in an XTR m9000 lever!? current internals doesnt last for s***t Link to comment Share on other sites More sharing options...
CdT85 Posted December 3, 2019 Share wonder if this will work in an XTR m9000 lever!? current internals doesnt last for s***taccording to the comment listed in the product reviews, there are people that used these successfully rebuilt their XTR's with these Link to comment Share on other sites More sharing options...
Meezo Posted December 3, 2019 Share wonder if this will work in an XTR m9000 lever!? current internals doesnt last for s***tThe feeling on your lever is not the piston getting stuck but rather the lever losing bite, i think the plausible explanation is the bore of the cylinder is phucked. This could be caused by bad maintenance and weight savings in the xtr lever babse 1 Link to comment Share on other sites More sharing options...
Meezo Posted December 3, 2019 Share Reviving an old thread here. Stripped out mate's stuck down M7000 SLX lever last night and found that the piston/plunger head is mushroomed. And seems that my M785 XTs isn't far from reaching that point also. Found these kits on Ali Xpress. Works out to about R190 with shipping if anyone want to attempt to rebuild/revive their lever. https://www.aliexpress.com/item/32973287602.html?spm=a2g0s.9042311.0.0.3c344c4d9QAbRL Lead time sux a bit, but will provide feedback on these and the rebuild process if and when they arrive one dayBeen running those in my Guides. Work well. Busy reviving another set of guides now, but the internal circlip pliers i order was damaged and CCS don't seem to list them on their site. Time for the dremel CdT85 1 Link to comment Share on other sites More sharing options...
babse Posted December 3, 2019 Share The feeling on your lever is not the piston getting stuck but rather the lever losing bite, i think the plausible explanation is the bore of the cylinder is phucked. This could be caused by bad maintenance and weight savings in the xtr leveryeah probs... solution = bin them and get XT M8100 Link to comment Share on other sites More sharing options...
droo Posted December 3, 2019 Share The feeling on your lever is not the piston getting stuck but rather the lever losing bite, i think the plausible explanation is the bore of the cylinder is phucked. This could be caused by bad maintenance and weight savings in the xtr lever Lever biting, but then getting closer to the bar under pressure? More likely a worn or damaged seal than lever bore. Strip and check if you've got a bit of time off the bike. Link to comment Share on other sites More sharing options...
fcwailei@gmail.com Posted March 18, 2020 Share Hi, I'm encountering the same issue on my m785 fron lever is more affected then the rear one. Can someone please tell me the material of the piston inside the master cylinder? is it from plastic/composite or metal? I'm asking this because on aliexpress i can see that the same seller is selling aprons(rubber o-rings) separately and he is also selling a metal piston together with the o-rings. https://bit.ly/2IYe5eo https://www.aliexpress.com/item/32973287602.html?spm=a2g0s.9042311.0.0.3c344c4d9QAbRL And don't know which version is better to buy. Apparently , if the original piston is from plastic, it seems a better idea to buy the whole metal piston, but don't know how will this impact the entire system. Let me know you're thoughts. Link to comment Share on other sites More sharing options...
Meezo Posted March 18, 2020 Share Hi, I'm encountering the same issue on my m785 fron lever is more affected then the rear one. Can someone please tell me the material of the piston inside the master cylinder? is it from plastic/composite or metal? I'm asking this because on aliexpress i can see that the same seller is selling aprons(rubber o-rings) separately and he is also selling a metal piston together with the o-rings. https://bit.ly/2IYe5eo https://www.aliexpress.com/item/32973287602.html?spm=a2g0s.9042311.0.0.3c344c4d9QAbRL And don't know which version is better to buy. Apparently , if the original piston is from plastic, it seems a better idea to buy the whole metal piston, but don't know how will this impact the entire system. Let me know you're thoughts.It's plastic I ordered titanium pistons I'm going to fit on my guides. Link to comment Share on other sites More sharing options...
Register a new accountSign in
