Rear Shock bolt keeps snapping
Sven137
HI
this is the 2nd time its happened.. when i went through a dip and the bike was at the bottom i heard a loud crack and the rear shock bolt snapped at at the bottom of the shock
I weight 90kg and am on a 29" Yeti
Are there diffrent thicknesses of bolts for the rear ? or am i riding wrong as i want going that wast and the dip was small .. it was at the Enchanted Forest at NF
Check your shocks air pressure.
The shock air pressure was about 12 13 bar Bar as i followed a youtube tutorial of only allowing 25% travel on the rear shock when sitting and adjusted the pressure accordingly which was 13 bar
Titanium bolts could be an option, but check the other things like pivots, shock pressure (according to sag, not pressure), etc. first. With the shock loose you should be able to check that the suspension cycles easily.
Buy a few of the screws that are currently used for the mount bolt and see if you can find A blacksmith that can harden them up even more
considering its a yeti I wouldn't but it can work.
But I think something else is at fault causing much more stress on the bolt
Are you the first owner?
Who replaced the first bolt and with what?
How old is the bike?
The Bike was built for me... Yeti Frame, Cannondale front fork...;
the bolt was replaced at LBS in Northgate
Bike about a year old now
Is the bolt braking on the same spot?
Yes.. same bolt same place
Nope.
High tensile steel.
Were you sitting down going through the dip?
You need to be out of the saddle to allow your legs to absorb the bump. Your calves are better shock absorbers than anything Fox or Rockshox can make.
The combined force of the dip and your weight will be too much if sitting down.
If you were standing up and this happened, then something is seriously wrong.
