Garmin Edge 520 battery life
mecheng89
Hi Hubbers,
To those who own a Edge 520, who can realistically get 15 hours out of that unit?
After 7 or so hours yesterday, the battery was already on 18%. Here are the functions that are turned on -
Brightness - 60%
Bluetooth
HRM
PM
GPS +GLONASS
Maps (during yesterday's ride)
What power-saving tips can you recommend? If worst comes to worst, can I purchase a new battery from NavWorld or someone else?
Turn off Bluetooth. Makes a massive difference in battery life on my 510. Screen brightness is also a big battery killer. Set to light up when touched if you don't need to constantly look at it.
+ normal GPS is fine
But my power data is displayed on it. I cannot ride without it
As stated before, turn Glonass off
AFAIK, the biggest battery eaters are (in order): GLONASS, Screen brightness, BT, Maps).
Some place active map use (navigation) before screen brightness.
There has been a discussion on the 520 battery life on here before.
WTF is GLONASS anyway? Something Soviet?
It's a Sovietski GPS service (a separate satellite cnstellation) that augments elevation (IIRC). Also, it operates more at higher latitudes - SA is very much mid-latitude, so shouldn't be a concern for us. I guess unless there's a reason to turn it off, just leave it on
My 520 does not have as good a battery life as my 510, so I need to keep an eye on it.
I squeeze about 12 hours per week/ charge out of it with bluetooth switched on.
(HR, cadence, Di2 and screen on 30%. I don't run maps or power, so hardly touch the screen)
Unfortunately turning the BT off is not a possibility. SO request and it's very nifty for notifications (calls, texts etc.).
I run the screen at 10%.Still clearly visible. Makes a big difference.
I've noticed in bright daylight I can set the screen brightness to 0%. What does screen brightness matter in the day anyway?
What power meter do you have? Turn off bluetooth connection to your phone.
Bluetooth with phone connection will eat up the battery quickly.
