  • Replies 50
Some of the guys print 3d mounts, I went with a GoPro DIY mount. Will see if I can load photos later.
I've got the mount, that's not the issue, I am looking for lights that can mount to it.
eg:
Ebike%20Micro%20Drive%20500%20(1).jpg?w=
You mean one that will fit in the cradle or just something that can be attached to the GoPro mount on the bottom of the Garmin mount?
I recently managed to get a Lezyne light attached to the GoPro mount, only bugger is finding the little attachment that you bolt to the light and then interfaces with the GoPro mount. In the end a kind hubber 3D printed a few for me.
This.
I have the mount and can mount my Varia, I am just looking to replace the Varia light.
Any good recommendations for lights that are compatible with these mounts?
IMG_0142__75692.1568777406.490.588.jpg?c
I have a Varia, but it doesn't last more than an hour anymore, and its very expensive to replace.
So you want something like a ryder 900 and that mount that connects to the bottom of the garmin?
My front Varia still lasts a good 4 to 6 hours on the non flash setting. its 18 months old and has had a fair amount of use.
Maybe contact Garmin to replace.
Edited by IceCreamMan
I want a light, that is not a Varia, that can mount directly to a Garmin mount.
That looks like the same size bracket as the Ryder version. Sportsmans warehouse..
Not in warranty, which is a shame, I have probably only used it 20 times. It only came out now as my riding picked up and the light has faded.
Pity, mine works brilliantly (indeed a pun) and like amex i never leave home without it on my roadbikes.
