Ivan Bergman Posted May 18, 2022 Share Howzit everyone! Been on the Hub for a some time but never really participated in any meaningful way, hence the new topic. I did a quick search and found that the discussion on this topic is fairly old, perhaps outdated. Does rim tape brands/materials really make a difference? Some people/shops swear by a certain brand or type, others are on the opposite side of the spectrum. I'd like to know your take and experience? Edited May 18, 2022 by Ivan Bergman Corrected first paragraph. Can't make innacurate claims. Link to comment Share on other sites More sharing options...
Koos Likkewaan Posted May 18, 2022 Share 1 minute ago, Ivan Bergman said: Howzit everyone! Been on the Hub for a few years, but never really participated in any meaningful way, hence the new topic. I did a quick search and found that the discussion on this topic is fairly old, perhaps outdated. Does rim tape brands/materials really make a difference? Some people/shops swear by a certain brand or type, others are on the opposite side of the spectrum. I'd like to know your take and experience? I don't think so. I've used Ryder with no issues, and now using Gorilla tape with no issues. I think it is more about the care taken when applying than the brand used. Dexter-morgan and Ivan Bergman 2 Link to comment Share on other sites More sharing options...
MTBRIDER1234 Posted May 18, 2022 Share 1 minute ago, Koos Likkewaan said: I don't think so. I've used Ryder with no issues, and now using Gorilla tape with no issues. I think it is more about the care taken when applying than the brand used. Agreed, I have never found it mattered. If done well, any brand or like Koos said, even gorilla tape can work. Just remember to put electrical tape on the rim before you apply the rim tape. Ivan Bergman and DieselnDust 1 1 Link to comment Share on other sites More sharing options...
Thomo Posted May 18, 2022 Share Brand unlikely to matter, but can indeed be different. For example, some may require two layers others can get away with one. Some may work better with a layer of insulation tape as mentioned. Then of course there's the issue of removal ... some can be a real pain. MTBRIDER1234 and Ivan Bergman 2 Link to comment Share on other sites More sharing options...
Pieter-za Posted May 18, 2022 Share 2 minutes ago, Thomo said: Then of course there's the issue of removal ... some can be a real pain Enter Xylene... Ivan Bergman and DieselnDust 1 1 Link to comment Share on other sites More sharing options...
MTBRIDER1234 Posted May 18, 2022 Share 13 minutes ago, Thomo said: Brand unlikely to matter, but can indeed be different. For example, some may require two layers others can get away with one. Some may work better with a layer of insulation tape as mentioned. Then of course there's the issue of removal ... some can be a real pain. On that note, only use 1 layer in stan's rims. Ask me how I know 2 layers is too much haha Jackie Thamsanqa Maholwana, Ivan Bergman and mazambaan 3 Link to comment Share on other sites More sharing options...
DieselnDust Posted May 18, 2022 Share What’s with the wizards brew’s??! insulation tape? xylene????! MTBRIDER1234 1 Link to comment Share on other sites More sharing options...
MTBRIDER1234 Posted May 18, 2022 Share 2 minutes ago, DieselnDust said: What’s with the wizards brew’s??! insulation tape? xylene????! Just been taught by the mechanics where I work that insulation tape generally helps it stick better and just helps overall. The way I have been doing it for a while, and luckily never had to redo it once. Jackie Thamsanqa Maholwana 1 Link to comment Share on other sites More sharing options...
DieselnDust Posted May 18, 2022 Share Polyurethane tape with polyurethane adhesive (Stans, American Classic, Dt Swiss) work very well and provide penetration resistance. Duct tape works but is poor when you hit a porcupine… gorilla is also good. 3M fibre tape is still a good option too as is fibreglass reinforced tape MTBRIDER1234, Mtree and M L 1 2 Link to comment Share on other sites More sharing options...
DieselnDust Posted May 18, 2022 Share 1 minute ago, MTBRIDER1234 said: Just been taught by the mechanics where I work that insulation tape generally helps it stick better and just helps overall. The way I have been doing it for a while, and luckily never had to redo it once. But the insulation tape has poor adhesive properties….  the only time it’s useful is if you want to make the tape thicker to allow the tyre to seat faster Link to comment Share on other sites More sharing options...
MTBRIDER1234 Posted May 18, 2022 Share 1 minute ago, DieselnDust said: But the insulation tape has poor adhesive properties….  the only time it’s useful is if you want to make the tape thicker to allow the tyre to seat faster Just how we have been doing it for years. Pretty sure it helps it stick. Link to comment Share on other sites More sharing options...
Pieter-za Posted May 18, 2022 Share 13 minutes ago, DieselnDust said: xylene????! To clean up sticky glue - not sure re use on carbon but works very well to remove e.g. Gorilla tape remnants from alu rims. Re two layers - Stans recommendation is two layers for road tubeless setups. (Depending on pressure) Quote Stan's Yellow Tape is designed to work with tubeless-ready rims and wheels. If you'll be inflating your tires to 45psi or less, one layer of yellow tape in the bed of your rim is all you need for most rims. For road tubeless and similar tires that require more than 45psi of pressure, a double wrap of tape is required.  Edited May 18, 2022 by Pieter-za TheoG and DieselnDust 2 Link to comment Share on other sites More sharing options...
Martin PJ Posted May 18, 2022 Share I use any duct tape, cheaper the better. Don't believe insulation tape adds any value. Once I put the tape on I run a tire lever along the bead on both edges to make sure the tape is plush against the rim. DieselnDust 1 Link to comment Share on other sites More sharing options...
DieselnDust Posted May 18, 2022 Share 1 hour ago, MTBRIDER1234 said: Just how we have been doing it for years. Pretty sure it helps it stick. you would be better off using celotape Link to comment Share on other sites More sharing options...
Ivan Bergman Posted May 18, 2022 Share Got a set of new rims over the weekend, just finished cleaning off the adhesive. I'll give both methods a try. One rim with a layer of insulation and one without and post my findings. MTBRIDER1234 and MajG 2 Link to comment Share on other sites More sharing options...
EddieV Posted May 19, 2022 Share Also remember to file down the spoke holes if it's a new build with a Dremel file or alike. Sometimes the spoke access hole is quite sharp and with a little pressure the rim-tape will rip/push through, even with 2 layers. Link to comment Share on other sites More sharing options...
Register a new accountSign in
