Going from Large frame to Medium
Rouxenator
I have a couple of bits lying around and was toying with the idea of putting it all together as a backup MTB. I usually ride Large frame bikes and some reckon I should actually be on a XL frame. Sometimes I do ride my wife's XS frame 26er but only for short distances.
Now for my backup bike I see there are a few nice frames available but all are Medium sized. What are the pros and cons of a large frame rider on a medium frame bike?
Would you wear a shoe that is too small for you?
No, coz it's uncomfortable.
So use a bit of logic and apply it to this situation too.
You are a large, so ride a large bike.
If you want undersized, go to the park and play on a swing
It is not uncomfortable for me when I ride a XS frame bike, and I did do my first K2C on a Medium frame bike that I borrowed. So I get the shoe analogy but it is not quite the same as bike frames.
How do you even get your saddle close to high enough on a XS?
Using a 400mm post wont even get you there.
Sounds like you WANT to crack another frame!
Contact Roshambo.
He's got a L Morewood Zula frame.
Mountain bike frame sizes are not universal. They differ vastly across brands, models and intended uses. You cannot reduce the right size to a simple S/M/L label. Also, a good fit includes stem length and hight, and saddle hight and position. Bar width, crank length, saddle width, and many other bits go into a good setup.
Shops will never tell you this because they are either stupid, or just want to make it easier to sell what they have on the floor...
  On 10/27/2014 at 6:10 AM, Rouxenator said:
Ok, so there is a higher risk of cracking the frame if you are too big for it, makes sense. Thanks I'll keep that in mind.
Stop talking *** and being lured into stupid conversations... Get yourself a proper bike fit based on your body and don't listen to idiots
My trail bike is a large and my SS is a medium.
All you'll need to do is have the seat post higher and use a shorter/up-slanting stem. Kinda obvious you can't have the same dimensional setup on the smaller frame, but you know that.
I find it really awesome - the smaller frame will teach you to handle better and you'll have loads of fun throwing the bike around!
What size wheels? I've got an XL 26" Zula going if you're interested...
To state what I assume should be obvious. Not all frames are made the same, a medium in one bike could well be a large in another.
You need to look at the geometry of each bike, in particular, the Effective Top Tube (as stated by Robodog) as well as stand over higher.
Ride what is comfortable for you. If it is a Medium, so be it.
The wrong size can also have an effect on your confidence on gnarly stuff and singletrack... But it doesn't sound as if you do much of that.
I am 1.83m tall and ride a Large Giant. A medium just can't work for me, no matter what I do to try and make it work (stem, seatpost, etc).
I agree with previous posters, if you want to take it serious and feel comfortable on your bike, get a proper fitment, or if you don't want to pay for that, at least see what feels most comfortable.
