Home made wax lube for chains
hagar
  • Replies 191
33 minutes ago, DieselnDust said:
Are you sure it’s slack wax?
it would make sense as it’s cheaper and less refined than paraffin wax
Found it in one of the Safety data Sheets, Slack wax has more Lube in it.
You can Feel that Squirt is "Softer" than Paraffin wax. Made in Knysna. The Bearing man Stuff is also made in Knysna and the bottles are same Shape Different Colour. (Some Useless Info)
Google Go Wax Lube Safety Data Sheet.
I buy it from Cycle Lab.
Edited by dasilvarsa
Link to comment
Share on other sites
Yes slack wax is higher in oil content , mostly paraffinic oil hence I prefer to use the more refined paraffin wax or candle wax also known as pharmaceutical wax. I can add back t own oil that has higher viscosity (film strength) and has a better mix of oil. Squirt would use the less refined cut of FT synthetic wax if they are still buying their wax from SASOL. It’s that FT wax that gives Squirt the edge
Link to comment
19 minutes ago, NotSoBigBen said:
'Slack' wax ... no wonder my bikes are slow! Demmit ... so which lubes are not slack?
If you find out, let me know please.
Maybe the same place those lucky contaminated supplements can be found.
Link to comment
I actually found that the Go Wax lube from Bearing Man Lasted a bit longer than Squirt and was a bit creamier to the feel. I'm back on Squirt from Cycle Lab and have stopped playing around anyway.
Link to comment
Guess who waxed his chains last night and got pissed on this morning ? 😅
Squirt on the road bike for the next couple of weeks it is 😮‍💨
Link to comment
  • 1 month later...
So to hot melt wax a chain, to start off with, the chain needs to be cleaner than clean. how do you get it that clean if you dont have an ultrasonic bath?
Link to comment
Check out zero friction cycling's site, the best info you can find on waxing https://zerofrictioncycling.com.au/
For chain prep... https://zerofrictioncycling.com.au/wp-content/uploads/2022/05/Chain-prep-Guide-Concise-v2.pdf
Link to comment
I've been using Enduro Seal's new hot wax. So far I'm impressed. This is my first experience with hot wax so unfortunately don't have anything to compare it to.
Link to comment
did not know that they have a product, good to know.
Link to comment
Where did you buy it from? I saw it their website but like I understand it, you need a retailer to buy it from.
Link to comment
I got it from them directly. Pop them a message or give them a call 🤙
Link to comment
