Did you buy it separately or did it come with the bike? If its the latter maybe you can dig up an old advert for it online and check the specs.
Google results indicate you are correct. That is how i remember my saddle. Thank you very much. Now to find one...
Yes around that age. New arione shape differs though. Mine had split tail where new arione has single tail
Then it was not an Arione so you can cross that off.The Arione has always had that same shape
How did you break it? The way you say " I broke it and threw it away now i need a replacement" just sounds like it could be a funny story like the time I broke my old gate motor and threw it across the driveway and needed a replacement as apposed to it broke itself.
You'll struggle to find a new one, look out for a used. Or, the Aliante Gamma is pretty similar, and you can get a new one.
