Depends on the model and build kit and heavily dependent on tyres.
But not a lot. Not nearly enough to be concerned with the mass.
But it looks like the base model Comp is around 12.2kg.
Edited by Thermophage
had the Epic Evo Expert 2021 size large on demo last week...11,5kgs without pedals...2022 should be a touch lighter since the Rovals are 200gr less
Expand
Thanks for the info.  Im looking at getting the base model, below the Comp, but I see there is not much difference between the 2 models, and with carbon wheels and few upgrades over time it should bring down the weight nicely.
Expand
Thanks. Yeah the Expert seems pretty light. I'm interested in the Epic Evo base model.
I wouldn't say so for a base spec bike. The components will be a lot heavier than the higher end models, whilst the frame is the same, which is why it is cheaper. For example the fork is probably 800 grams heavier than a SID and the cassette 300 grams more than an XT version. 1.1kg right there,. The nice thing is you'll feel big changes when you upgrade it. For example a set of carbon wheels
Edited by thebob
Expand
I bought the Epic Evo Comp and moved my Enve Wheels, Cockpit and AXS Groupset across
14.5kg  for XL  aluminum  ready to ride , add garmin,  water and go
NX 1x12 , plenty sealant , Pedals , oversize grips ,Sahmurai Sword ,  garmin mount , z-cages , swat box with tube, tools and co2 adaptor  , chain break and multitool in headset
@ 115kg myself the bike is fine 😉 .
Edit : this is 2020 version with minibrain
Edited by Milosh
Expand
Agreed,  I have carbon rims and handle bar to put on it, so would bring it down a little bit.  Will need to plan the next upgrades from there :)
