You use a normal wheel and replace the cassette with a SS cog and spacers, the coloured spacers in this pic, (red, gold silver etc) are used to position the rear cog in direct line with the front chainring. You then use the tensioner as shown to take up the slack and keep the chain tensioned.
Sometimes you are lucky and if the gear ratio you choose with the frame dimensions, the chain may fit tight without the need for a tensioner and this is known as the "magic gear"
http://www.velosolo.co.uk/pictures/dscn4307FAQ.jpg
you can buy tensioner kits such as this http://dialdbikes.co.za/dmr-single-speed-conversion-kit.html
Also here http://www.rapide.co.za/c228/Single-Speeder.aspx#.U-w-r_mSwkM
Thanx for the info...
  • Replies 2k
Happy to help, enjoy the build
Ensure that the front chainring and cog are in a straight line, sometime you can do this by eye, else use a straight edge, piece of wood or something. If they are not, as soon as you start pedaling the chain will come off the cog.
Enjoy the simplicity of riding without having to worry about gears and the huge grin it generally brings :D
If anyone has a large frame "lying" around thats willing to swop for a paintball gun (BT4Combat +extras)... please let me know... Thanx. ..
I have an issue that I'm trying to solve in the least ghetto way possible.
The frame was built for mechanical disk brakes. No provision was made a hydraulic hose.
I had a similar problem on my SS roadbike (the frame doesn't have cable lugs at all), so I did a bit of research and drilled the frame. Now granted it is a roadbike, so a lot less stress on the frame but I do ride like a hooligan, jump curbs, stairs etc, and the frame hasn't broken yet... I have done around 200km since doing it
Here's a link to the post https://community.bikehub.co.za/topic/140426-diy-internal-cable-routing/
I have a large frame that you can have for less than that.
Damn, I would have gone for that deal. Good luck with the build.
Let me know if there's anything else you need. Brakes, wheels etc.
Edited by Robodog
Guys! Does anybody know if/where I'll be able to buy/beg a Salsa El Mariachi frame in R of SA? Saw one this weekend and it looks sweet. :drool: Looking to sell one of my kidneys for a ss frame.
Does anyone have some experience with it? (With the Salsa, not my kidney).
From Grant Usher
