Grease_Monkey Posted January 28, 2021 Share That friend is very clever. Or maybe he just had a look at the instructions on how to setup the Eagle derailleur. SRAM made if very clear that the B-Gap tool should be used when the bike is at the desired sag position. Anyway, sort out that noise, I don't want to ride with someone this weekend with a noisy bike. Ja Coenie, jy is slim. Maak jou fiets al minder geraas? Ek luister al weeke lank na daai lawaai! Edited January 28, 2021 by Grease_Monkey Link to comment Share on other sites More sharing options...
DieselnDust Posted January 28, 2021 Share I will give that a go. Interestingly a friend of mine says he uses that tool with the bike at it's sag point and gets better results - your point supports that.Yes for FS bikes one has to set the b gap with the bike loaded to the sag point Link to comment Share on other sites More sharing options...
Grease_Monkey Posted January 28, 2021 Share Yes for FS bikes one has to set the b gap with the bike loaded to the sag point I should read instructions in future. Mtree and DieselnDust 2 Link to comment Share on other sites More sharing options...
CJ Van Posted January 28, 2021 Share Ja Coenie, jy is slim. Maak jou fiets al minder geraas? Ek luister al weeke lank na daai lawaai!Nuwe chain ring het vandag hier aangekom. Ek join nou officially ook die bling bling club. Hopelik gaan my bike nou mooi stil wees. Grease_Monkey 1 Link to comment Share on other sites More sharing options...
DieselnDust Posted January 28, 2021 Share I should read instructions in future. Lol ya it is explained in the manual Grease_Monkey 1 Link to comment Share on other sites More sharing options...
Mtree Posted January 29, 2021 Share Hi all, what chain lube is best for these drivetrains? Previously used squirt, I am finding that it's attracting a fair amount of dirt. Link to comment Share on other sites More sharing options...
DieselnDust Posted January 29, 2021 Share https://community.bikehub.co.za/topic/188037-squirt-lube/page-2?do=findComment&comment=3764201 i tend to make my own lube to stay out of What lube fights and debates. but yes Squirt makes a mess if you apply too much. Smoove makes a mess if you apply too much BAT makes a mess if you apply to muchMuchoff is a ripoff for a cleaner easier to clean drivetrain, Finishline Wet lube is great if using wax, expect it to pack onto your chainrings and derailleur jockey pulley wheels Edited January 29, 2021 by DieselnDust Mtree 1 Link to comment Share on other sites More sharing options...
Carmichael Posted February 4, 2021 Share Boys quick Question, went to go and buy new xx1 eagle chain, checking youtube vids now.. must i shorten the chain still? Same as what i had on. Edited February 4, 2021 by Carmichael Link to comment Share on other sites More sharing options...
DieselnDust Posted February 4, 2021 Share Yes, the chain is 126 links most bikes require 119 to 123 links Link to comment Share on other sites More sharing options...
babse Posted February 4, 2021 Share Just replaced xx1 eagle chain after 7k km. Running XX1 cassette that definitely still have miles left on it. Bottom 4 cogs show signs of wear and the rest is almost spotless.Under load the bottom few cogs slips. Under normal/high cadence its all good. The shifting up and down is fine too.Normal?So in the meantime I put my old chain back as the slipping made riding less enjoyable. Will change cassette and chain together within the next week or so... Seems me running chain too long killed the cassette (3 cogs at least) way sooner than it should have. It should still be rideable with a chain with a +1000kms on it. Expensive lesson learnt DieselnDust 1 Link to comment Share on other sites More sharing options...
DieselnDust Posted February 4, 2021 Share Sorry to hear this Babs That's exactly why I don't even go to 0.5% wear. I replace earlier at 0.3% Wayne pudding Mol 1 Link to comment Share on other sites More sharing options...
Mike Mac Posted February 4, 2021 Share Only got 1000km on GX chain (0.5). Have replaced with XO. Plan to rotate this chain at 1000km as well. Hopefully the rotating helps me get reasonable km out of the cassette. DieselnDust 1 Link to comment Share on other sites More sharing options...
DieselnDust Posted February 5, 2021 Share The price difference between the XO1 and XX1 chains is 10%,smalk enough to trump up to XX1 and then rotate 2 off. Replace both chains well before 0.5% like 0.25 to 0.3 % and the cassette will last a long time Link to comment Share on other sites More sharing options...
Mike Mac Posted February 5, 2021 Share The price difference between the XO1 and XX1 chains is 10%,smalk enough to trump up to XX1 and then rotate 2 off. Replace both chains well before 0.5% like 0.25 to 0.3 % and the cassette will last a long timeHi Thanks for that input. The reason I went with the XO1 over the XX1 was because of the article that was shared here (which is an in depth study undertaken on the performance and durability of all the Sram chains), which indicated very little difference in performance and durability between the X01 and XX1 chains. My conclusion (and that of the person hat posted the link to the article) is that with the X01 you getting better bang for your buck. Did I miss something? DieselnDust and Christofison 2 Link to comment Share on other sites More sharing options...
Christofison Posted February 5, 2021 Share Hi Thanks for that input. The reason I went with the XO1 over the XX1 was because of the article that was shared here (which is an in depth study undertaken on the performance and durability of all the Sram chains), which indicated very little difference in performance and durability between the X01 and XX1 chains. My conclusion (and that of the person hat posted the link to the article) is that with the X01 you getting better bang for your buck. Did I miss something?That was the conclusion of the article, correct.Someone needs to join half an XO1 chain with half an XX1 chain and measure wear with a digital guage of each half over time...similar to what this guy did with Shimano.https://youtu.be/ZrCp52b34Uk Link to comment Share on other sites More sharing options...
DieselnDust Posted February 5, 2021 Share Hi Thanks for that input. The reason I went with the XO1 over the XX1 was because of the article that was shared here (which is an in depth study undertaken on the performance and durability of all the Sram chains), which indicated very little difference in performance and durability between the X01 and XX1 chains. My conclusion (and that of the person hat posted the link to the article) is that with the X01 you getting better bang for your buck. Did I miss something?The XX1 has consistently outlasted the X01 by a factor of 3x in my experience. I read that article and dismissed it as nonsense. Even SRAM wouldn't expected 6000km out of the X01. Their guidance was roughly 2500km and I achieved 2300 on one.not worth the 10% saving. Mike Mac 1 Link to comment Share on other sites More sharing options...
Register a new accountSign in
