Aluminium weld for a hairline crack on chainstay
edkin
I have discovered a hairline crack on the chainstay making up the subassembly on my bike. Probably caused by a siezed bearing. The bike is a Ghost so I don't think I'll find a new sub assembly very easy.
Does anybody know and can recommend somebody that can do a decent Aluminium weld in the Cape Town area?
Alternatively, any other ideas?
Any Advice (except to go vegan) will be appreciated.
  • Replies 50
Maybe if you go vegan it will fix itself? And the whole world according to Hamilton.
If you don't come right in CT, Tigco Tech welding in Centurion, Gauteng will no doubt be able to sort it for you.
Thanks. I'll try and do a local search first before I start spreading the net
The chances of an aluminum weld holding is very slim. Rather, the weld will probably hold but it will often crack again next to the weld. If you want to take the chance, I've got a friend who does laser welding, which is probably your best bet there. His name is Erich and their company is called Luxus Jewelers, they are based near Stodels.
Definitely worth a try. Would you be able to pass on his contact details?
I had my training tandem welded where the chain stay joins the rear BB and have ridden A LOT of miles and had zero issues with cracking anywhere else. Done properly, it shouldn't crack next to the weld. If it does then there is something else wrong. We weld aircraft parts!!!!!! and that is an approved repair by the OEM.
My brother had the chainstay of his tandem welded, held up just fine for the 3 years he kept it and YES he did tell the buyer...
Broke two Ghosts in exactly the same spot...on the cable guide piece on the drive side chainstay.....I did go vegetarian after this though.....
That is probably because the frame is not properly heat treated post weld - there aren't many places that can do this, and there are no guarantees on paintwork afterwards.
The other issue is putting too much heat into the weld - this is a common problem for less than really competent tig welders (me included)
That said - hubber AMPANDY is pretty good at tig work - worth pinging him to see where in the world he is working.
