Since I only use wax based lubricants for my MTB chain, I was wondering if immersing the chain in boiling water will assist in cleaning it? The melting point of wax is below the boiling point of water, therefore the lube should "melt" and lift from the chain together with the gunk stuck in it? Dont think boiling water should in any way be a problem for a steel chain?
Any-one else who have tried this or can tell me why it cannot work?
I used to use hot water and a splash of sunlight liquid, chuck the chain in an old marg tub or something with a lid (don't use boiling water here!).shake it around..clean it up..rinse it off..let it dry...wipe it down...lube it up...
Yes it assist - I dump my dismantled cluster sprockets in hot water + degreaser and then wipe it clean with kitchen paper towel much easier.
Ditto with the chain - easier to wipe the outside clean while hot.
ultrasonic cleaner- thank me later...
Sounds like a good idea. I've wanted one for cleaning some antique razors, but if it can serve another purpose then it might justify the purchase.
I have one - and it work even better when starting with hot water. (* I use wax based lube)
One thing - it take long - Mine is small/not industrial product
