Hoping the wise hubbers can help
I have deeds hub 6 pawl hubs that are not engaging when I pedal.
Removed the hub to check if hub was gunked up or not moving freely etc.
We did all the basic checks of the pawls and springs and they all move as they should but the ratchet teeth in the hub also moves, which I doubt that it should.
As I back pedal it moves perfectly and noisy as usual.lol
This pic is for reference,  to show what part is moving. Should it ? If not why would it rotate and feels fairly stiff as it rotates
Then pic of the deed hub, can't find too much info on the web about  deed hubs.
16 minutes ago, BaGearA said:
S0 the ring with the teeth that prawls engage into is rotating ?
If yes i don't really have a btter answer than A new hub
Yes It is rotating!  So it's screwed? Noooooo
Edited by MajG
How does the ring stay in the hub? Is it threaded or bonded? Either way can be repaired if you find an engineering works that can help you. Should be a lot cheaper than a new hub as well
If you can get it out, even it is threaded and it has stripped, you could put it back in with a little Loctite 613 I think it is, it will NEVER come out again, pretty sure if you dripped some around on the seam where the driver meets the body, enough will hopefully work its way between the surfaces that it will work as well
Edited by Chadvdw67
38 minutes ago, Jewbacca said:
If you pull it out, you may be able to see if anything has broken off in a slot or what not.
You should be able to bond that really easily.
SP340 epoxy bond will keep that in place forever
I think I will attempt this instead of paying Btwn R2500 to R5k for new hub
24 minutes ago, tubed said:
If you dont come right, take it to the guys at Knipe Racing, I'd back them to either resolve the issue or give you an honest opinion.
This will be my last option, thanks
8 minutes ago, Chadvdw67 said:
If you can get it out, even it is threaded and it has stripped, you could put it back in with a little Loctite 613 I think it is, it will NEVER come out again, pretty sure if you dripped some around on the seam where the driver meets the body, enough will work its way between the surfaces that it will work as well,
Definitely will try this
Wish me luck
Wish me luck
Just edited my comment, should have said "will hopefully" work into place, no guarantees that it will work 100%
3 hours ago, Chadvdw67 said:
This is the one....
Going to purchase tomorrow, today was like a crazy Monday
Hoping local hardware or builders has this
Also need to buy a proper pick to remove ratchet
Highly doubt you will get it at a general hardware store, will most likely need to go to a bearing shop
Also, don't buy any product that looks as though it may be an equivalent. Only use the real thing.
Keep in mind that ring transfer ALL the torque you put in into the wheel. Any type of glue or Loctite would keep it from falling out, but I doubt it will keep it from rotating (ie transfer the torque). If it does, it probably wont do it for very long and may fail when you least want it to.
I would get an opinion from a good bike mechanic (it is difficult to give advice without seeing the part first hand) and/or chat to Pyga (Deed are their component brand).
Yeah, I reckon Loctite is going to do exactly nothing aside from make a dent in your wallet. Epoxy should work if you can get the drive ring out and prep the mating surfaces properly though.
