Heat it up with A heat gun ( this might be just be my  mind playing tricks with me ) and go very slow
The problem is as soon as it forms A fold it will shear there immediately ,  bending ally back usually only works for me 1/5 times
Too risky for my liking. Not with a bend that big. Need a new blade I think.
Can still try and if it fails, just get a new one?
Same happened to me. I used a small kitchen blow torch (used for making crème brulé) to heat it up (glowing red) and bent it back very very slowly.
Heat it and bend it back.
I wouldn't bend it without heat, worst case you can HTS2000 weld it back together, assuming it's Aluminium.
Just another 2c here.
That will 80% come off if you try and bend it back imo, but worth a try i guess.
Everybody says to mend it with fire but Please for the love of the sky gods….just take the lever out of the brake lever assembly (if thats even possible) before you take a blow torch to it. AL tends to be an epic disperser of heat too you see…so you might just end up melting and boiling all the other crap attached to it🤣
Looks like the part is not available locally. (No surprises there)
Looking Amazon etc I guess to import. Alternative is getting a replacement lever and keeping the old one as spares then.
13 minutes ago, Steady Spin said:
I will have to find out. Thanks for the kind offer.
These are the ones i see so far on Bike24 - I would say your could be the 1st one as it does not have the indentations above or below the SRAM name like on the 2nd & 3rd pic
