I've run tubeless setups on insulation tape alone and it has been fine. But like the others have said it is not the most robust option. The best ghetto tape I've used to date is the Gorilla Tape. You can get it at Builders Warehouse.
I have been using Wurth tape for years now and still no problems. I believe 3M tape is just as good? Normal insulation tape has let me down on several occasions.
Wurth duct tape? Wurth makes good stuff.
I use insulation tape if I don't have proper rim strips. Over 20 wheels are currently rolling the roads on bikes I've donated with 3 layers of black 3M insulation tape between the tubes and the spoke holes.
