Good Afternoon
I will like to get some advise on a rear tire to match the current Recon 29 x 2.4 from.
i had a crossmark 2 29 x 2.25 which got a side wall cut a week ago, so now I' m thinking wheather I should get another CM2 or should I chance to 1 of the following Icon 29x 2.35  or Ardent Race 29 x 2.35.
I a heavy guy and run the rear @ 4.5 bar , less then that is rimming when I ride.
I am been mtb for a year and is still new to the sport. I mostly go to Buffelsdrift MTB park north of Pretoria
can some please assist with which rear I should go for
regards
Lukws
Holy Hell 4.5bar? It must feel like you are riding on solid steel wheels.
I am a light guy at 73 kg but I run front at 1.6 and rear at 1.8.
Tyre pressure aside, if you like the way the Crossmark II felt you can go for the EXO one with the tougher sidewall.
Would definitely recommend Exo+ casing...
Icon or Ardent race would be sufficient, can't really go more aggressive without the tail wagging the dog here...
Edited by Mtree
I like to run a hard tyre myself but around 2.6-2.8..(Assuming the gauge reads correctly)..I weigh about 85. Also the Crossmark. But the skinny 2.1 version. I know it seems hard but I have also seen a few tyres pop and sealant all over and riders going down in some races....Kind of puts me off being too soft on cheap rims....
Depending on your bike I would say check that your rear stays can take the wider tyre...
Im at my limits with a 2.25....
Edited by Mojoman
If I were you I'd go for a tyre with the strongest possible casing (i.e. Downhill casing, maybe Double-down will work too). At 160kgs, the weight saved using anything less is a sub-marginal gain. You won't find anything with an XC tread pattern and a downhill casing, but there are options such as the Maxxis Minion SS or Specialized Slaughter that will offer somewhat lower rolling resistance.
I don't have experience with a lot of tyres, but I have never damaged a Crossmark.  I always replace them because they did their job (they do puncture).
The Ikons on the other hand...sjoe, they don't last.  I am kind of exited to try the Recon Races next.
I do XC riding.
