Had a very dirty chain and ran out of cleaning stuff. Looked around and saw the toilet cleaning liquid. Put chain in a tin, diluted the cleaner with hot water, shook it around a bit, rinsed properly and dried with a rag = one shiny clean chain. It's a pleasure..............
Edited by Sepia
  • Replies 81
Just check that it is ammonia free - don't think your chain will take kindly to ammonia.
I use terps in container that I can shake with the chain in. I re-use the same terps as the dirt settles in a day or so and the clean terps can be decanted.
Edited by porqui
  On 7/14/2014 at 2:45 PM, Stretch said:
i am sure paraffin will be a lot more economical that household detergant
Similar method as above, put paraffin into bottle, dilute with hot water, drop chain in, shake and rinse chain off?
put in 2 litre ice cream container....submerge fully and leave for a bit...then take a drill with a circular buff atttached (can even use a bench grinder with buff) and vibrate from below......forces all the k@k out from the hard to reach places
Should one dilute the paraffin or not?
