Chain Master Link on a road bike
Weimaraner1
Master links are often used on a mtb but I have never used one on my road bike. It makes cleaning a chain so much easier on a mtb......
Anyone using it on their road bikes? Pro's and Con's?
I see Shimano now also supplies them so if you are a Shimano fan you do not have to use the SRAM link.
Feedback appreciated.
Have had on my road bikes for long time. Even have 2 of them on my interconnect chain on the tandem!!!(the interconnect chain uses 1 and a half chains) Have never had issues.
Single bike I have 2 chains(ultegra and kmc gold) and use the relevant quick links. On the tandem I changed from ultegra to sram chains as they seem to last longer so use the sram link there.
In short am using shimano, kmc and sram quick links and haven't had issues from any of them.
Edit: sorry come to think of it I think I'm using a kmc link on my ultegra chain. Would have to confirm.
I used them for several years, until one sunny day.......
Was riding along, my riding partners started sprinting up a small incline, obviously I decided to chase them, and that's the last I remember. Woke up in hospital.
The quick link seperated, I went straight over the bars. Broken helmet, broken bike, broken ribs, concussion. Since that day, never used them again.
Maybe it was just a dud, although at the time of the crash it had over a thousand k's on it, so it obviously wasn't a fitment problem. I put it down to bad luck and moved on with my life.
I always use them, buy them on eBay 5 to 10 at a time. They are very cheap. Seem to be as reliable as the expensive ones.
They are directional, the plate is larger on one side than another. The smaller side must enter the derailleur first on the left if you are standing behind the bike. If you get the direction wrong the chain hops when you are on the 11 ring.
I fit them to all chains.  Don't work on a chain without one.
I've heard other technical minded people saying they hate them.
me, I don't like them (failed on me) only use in an emergency.
as for cleaning chains Parktool CM 5.2
  • 2 years later...
i even stick them on my campy chains cause its easier than a chain tool - been using them forever
(make sure you use the correct speed link for your chain )and never a problem :thumbup:
they all made in china anyways (branding means very little )
If you not using them on Road and MTB you just spending unnecessary time during services having to break the chain. Unless ... you don't do your own services. Even just for chain cleaning, the master link is a must have. Buy them when they on sale and keep new ones handy. Ride with a spare Road and MTB all the time.
On topic hi-jack... I read someone saying they've used masterlinks on 8 speed chains too.
Would the following work? 8 Speed Shimano 105 HG chain; tap out a link; replace with general SRAM powerlink?
