  • Replies 133
25 minutes ago, love2fly said:
On a MTB the freehub needs regular maintenance. ( Roadbikes too especially if like me you ride a Mavic hub....) I've found this out the hard way. Hope this is your issue and that the patient is curable.
Regular maintenance done as well as inspection on the prawls etc.
Only the outer bearings were replaced recently. Will get the inners done as well.
XD driver is on the cards for later but might be needed sooner. If so I can sell the NX cassette and go for a Garbaruk
Sounds like the perfect opportunity to go for SHIMANO ... 😋
Sorry, just could not resist ...
Dunno....
I have hubs which have done upwards of 20000km and never undergone any severe maintenance. My old Hope SS hub was probably pulled apart once in roughly 7 years.
This included riding some helluva inhospitable terrain in some dire conditions, swimming in the baviaans and Mordor on Freedom Challenge, etc...
I reckon the more you tinker, the more you need to tinker.
You guys obsessed with always cleaning, polishing and degreasing your bikes always seem to be the ones with problems.
If the bearings feel notchy, replace them. There is a natural residue and build up of gunk that works in your favour. If you are always stripping that away you are creating problems.
Anyway, I am currently guilty of my favourite 'pool of 1' peer review study. Without any scientific proof and purely based on anecdotal evidence and 100% bias, I believe if you clean your bike and degrease everything too often you are going to wear through your kit faster than if you just rinsed things off and cleaned things reasonably.
24 minutes ago, Jewbacca said:
Dunno....
I don’t tinker to the level of causing more headaches though. Keep my bike clean and drivetrain maintained.
Wheel bearings only done now after about 18 months and 6000km. I blame cheap bearings from the factory  Fiance’s bike eats a set of bearings every 12 months.
If the seatpost creaks I clean and replace the fibergrip. Same with the bars.
Headset clean and regrease happens when the fork is serviced. So twice a year basically.
BB service happens when the chainring gets replaced. I’ve never needed to replace BB bearings in my life. Lucky I guess.
I really miss Hope hubs though. Never needed maintenance and just kept going and going on my Morewood. The new owner has the same experience I’m sure.
So yeah. Until recently I mostly just clean the bike twice a month and lube at the same time.
Edited by Steady Spin
I wasn't aiming at you specifically. More the comment about how hubs need regular maintenance and how some guys obsess about using paraffin and other degreasers to scrub out their chain and cassette etc...
Some of that is good gunk!
No stress. I’ve been tinkering like a mofo this week though 😂
35 minutes ago, Jewbacca said:
Dunno....
Agree with this - there is a fine line between ignoring an obviously degrading part/ problem which will manifest if it doesn't get attention and the need always to always be fiddling.
Best example was a good rider, and bike industry guy (always fiddling) - decides on Freedom Challenge near Baviaans to tighten more, an already perfectly tight quick release, which he strips by overtightening and then spends a day waiting for a new one from PE and another day riding like a madman to catch his mates.
Bike shops love these guys......
hence why I shower once a week😁
46 minutes ago, Steady Spin said:
No microspline driver available for my hub unfortunately.
Then get a DT Swiss Star ratchet hub .... 🙈😂
Wheel is back at the shop. I can’t bother with this anymore. Let someone else figure it out.
Shop suspects the freehub is the problem. They will reset the spring tension and relube it.
My question… why would a freehub only last 6000km or is that the norm? Lyne components high engagement unit.
I really miss my Hope hubs.
10 minutes ago, love2fly said:
Is it not possibly the disc rotor as the wheel flexexs under pedalling
Not impossible but it would be more frequent and only under load. I get the noise even under light loads.
Not sure it would make such a loud noise. What would it get caught on? Rubbing noise would be more likely.
