6 minutes ago, Steady Spin said:
This is becoming the definitive thread for all things creaking and also the importance of hearing loss and how it relates to a happy life.
if you cant hear your wife complaining about your n+1 obsession then life is happy :)
  • Replies 133
i had a similar issue that no one could nail down. I eventually solved it - it was the seatpost. but only when it was cold... when things warmed up, the noise went away... but learned a few things in the process - LBS said SPDs are not serviceable, which a 30s google search will prove wrong...
Mine is the opposite. Happens when warmed up which makes me believe it could be pivots or pedals. The two p’s that p me off to work on.
time for that hardtail maybe?
2 minutes ago, Prince Albert Cycles said:
Another cause could be spokes moving where they overlap .
Thought about that as well. Makes sense for them to “ping” under load where the wheel flexes a bit.
Definitely worth getting the wheels trued and tensioned to spec.
I have this problem and even with truing it still does this under load. Think next would be to respoke with stronger spokes.
54 minutes ago, Steady Spin said:
And the winner is….
Cassette. ******* piece of **** Sunrace. Been nothing but trouble from the start.
Massive amount of fiddling and redoing the shifting from scratch and it’s quiet again.
Reason why I recently moved away from sunrace,  caused constant issues on my drivetrain.
Will rather pay the extra money,  but sunrace never again.
Glad u got the click sorted
Thanks man
Only problem is I have a HG freehub so for now I’m limited to Sunrace or SRAM NX 12 speed cassette.
Microspline is also not available for my hub so I guess it is XD driver and GX cassette. I can’t wait 20 to 30 days for a Garbaruk cassette to arrive.
