3 hours ago, lechatnoir said:
thanks. that's really good news . a bit of googling would have answered my question, but hubber feedback is most helpful.
I built up a new bike recently and went the Shramano route, shimano chain and cassette (important for the hyper glide to work of course) with SRAM AXS - works like a bomb. Little bit of tweaking to get the shifting sorted (YouTube will help here) but super happy so far with the results. I agree with the comments above that shifting with AXS feels super counterintuitive out the box, so have been fiddling. The solution I’ve found for me is the upgrade paddle for the shifter (600 odd bucks) and then reversing the shifting from default, feels super now, but there will be much fiddling to get the desired spot, as keep in mind it it of course more sensitive to being trigger accidentally. But was thinking to myself last light how far we come as I quickly put my rear derailleur battery on charge…
P.S - only thing I have noticed which resulted in a fair amount of troubleshooting is that when back peddling on the Shramano setup, particularly on a drying chain, is that it’s noisy to the point where you think you might have a faulty bearing somewhere. So after a fair amount of looking I came to the conclusion it’s the narrow wide derailleur pulley wheels on the SRAM, much quieter though if chain is well lubed.
Edited by Murrob
  • 4 weeks later...
  • Replies 46
Trying to mix stuff but not having much luck so far.
Okay so my Force eTap rear derailleur fried, I ordered a new one but it's taking too long to get here. So I read a little bit online about how you can theoretically mix sram AXS components together https://blog.3t.bike/2019/09/12028/gravel-tech-hacking-sram-axs-drivetrains/. My goal is to take my GX derailleur and put it on my road bike until I get my new force derailleur.
I tried the whole pairing procedure before taking the GX off of my MTB and it works great. But it appears that that the screw that bolts the derailleur in the hanger is bigger on the GX/MTB than on the force/road bike ? Visually I can't really tell but couldn't screw in the GX in the road bike, I didn't insist too much. But the weird thing is that the force derailleur bolts in the MTB beautifully so I don't really understand. Anyone knows of different hanger diameters for road and MTB ?
I'll try to clean off the dry loctite tomorrow maybe I'll have more luck...
edit : okay I must be drunk, the old xtr derailleur I replaced the gx with fits nicely on the road bike (incredibly light by the way) so I’ll try again tomorrow with the GX, curious to see how it works. It’s going to look dumb and be stupid heavy but hey 😂
Edited by Jbr
It should bolt right on. Only challenge might be the lower NW pulley wheel may give some issues when shifting between chain rings especially in the little ring  it may skip once in a while. Easily solved with a non NW pulley wheel
yeah it did, it's really not great though on a 10-28T cassette. Like they say on that gravelers website they do it so they can use bigger cassettes than 33T. So at the moment I've got 14 gears I can't use. If I set the B limit screw so that I can use the small blade, then the derailleur is way too far from the cassette on the big blade. If I set it so that I can only use the big blade I'm missing the 2nd easiest gear and one random gear in the middle of the cassette that is a bit sticky. Still don't understand why sram wouldn't let us micro ajust gear by gear...
its not so much the micro-adjustment but rather that the MTB derailleur is only spring loaded at the derailleur pulley cage knuckle and articulates at this point during shifting because its designed to operate with a single chainring. Hence you will only ever be able to optimise it for one chainring. A derailleur designed to work with two chainrings has a spring loaded mounting ear and derailleur jockey cage so it can optimally tension the chain across both chainrings
Also 1x RDs have horizontal parallelograms and use the distance between the B knuckle and the top pulley to compensate for the change in cog sizes, where 2x RDs have a parallelogram that's angled to track the cassette. The horizontal parallelogram counters the sticky shifting from early clutch RDs by decoupling the clutch force from the shifter.
Either way, a 1x RD won't work on a 2x system.
yeah even using one blade only I couldn't really get the shifting good enough to make it raceable. I'm putting everything back on the MTB and will find another bike to race while I'm waiting for the new RD. Thanks for the input I tried, ;) would have been pretty cool if it worked !
Hi Hubbers,
I was asked a question this week and made me think....
Is there any "real" difference between an 11 speed crank & a 12 speed crank. eg XT m8000 vs XT m8100?
In other words, if you slapped a 12 spd upgrade kit and new front chainring, chain and cassette on your bike and kept your 11 speed crank would there be any detriment to the set up? It surely could only affect the chainline perhaps?
Also, anyone know of any differences between running shimano / sram cranks with the opposite brands cassette / derailleur? Any detriment there too?
Thanks in advance!  🖖
Edited by Cunning-Stunt
1 hour ago, Cunning-Stunt said:
Hi Hubbers,
Is there any "real" difference between an 11 speed crank & a 12 speed crank. eg XT m8000 vs XTm8120?
I'm running with a 2x (originally "10 spd") crankset in front setup as a 1x, no issues whatsoever.  I also see no issues running 1x with SRAM in front and Shimano rear or vice versa.  As long as the chainring is "narrow-wide" you should be fine.
It is important though to mount the chainring in the position that is best for the overall chain-line.
Edit:  imho, there is no such thing as a 10/11/12 speed crankset (only 1x, 2x or 3x).  If you run a 1x system, you can make any of them work with more or less effort.
Edited by TheoG
Thanks Theo. I'm of that same opinion. Maybe a spacer between the crank and NW chainring as an example but otherwise I don't see any "real difference"
On 11/8/2021 at 11:26 AM, copperhead said:
The problem lies within the manufacturers of stuff. If they made parts of cassettes available then that would work. The smallest 2 or 3 gears are the ones that need replacing. The rest are fine. But nooooo they won't do that. Full cassette. It someone made this option available then I would use their product. Unless you know a fix to this problem?
I have recently run into this problem when changing my chain that my smallest 11t cog was especially worn and would skip with the new chain. I found out that you can buy single 11t cogs (and a few other sizes) from wish.com for like R70. I have been running it now from 2 months and haven't had any issues. I know that the cogs themselves are cheap Chinese stuff and I will probably have to change it out sooner than the rest of the cassette but it has saved me from having to buy a new cassette now. Its worth giving it a try if you were planning on changing cassettes anyway. The delivery is through SAPO so it does take like a month to arrive but the SAPO does have an agreement with Wish to share tracking info so they do tend to actually arrive now, which is nice.
No I don't think it's worth giving a try.
  • 2 weeks later...
