  • Replies 292
This could have been so awesome, but seeing as it is still 11-42 only, it still lags behind the 10-42 offered by SRAM.  I have a conversion fitted to my existing XT drivetrain that gives me 11-42 anyway; so what's the point?  These conversion (OneUp and many others make them), are much cheaper than replacing half your drive train.  So what's the big deal then?
+1
My thought as well, all this hype and that for nothing... Already got a 11-42 (10sp) casette, was hoping for the 10t sprocket!
I'm a big shimano fan, but sram's still one in front!
I don't see the point of 3x11, what sort of wheelies are you going to pop with 22x42 granny gear?!
if it's a lower price point offering 3x10 (9) will be cheaper, more durable and offer same gear range.
All in all, looks like my 9 speed setup is getting even more cheaper
  • 2 weeks later...
That's why One-up has now announced a 45t rear cog for Shimano's new 1 x11 XT group. In the same way as the previous 42t extender, it goes inside the 11sp cassette and then you replace the 17t and 19t with a new 18t cog. You can do this with the new 11sp (11-40) XT cassette because it is not pinned or milled from a single block of material like their SRAM counterparts. The gears ramp more smoothly than the 11-42 10sp extended cassettes because the tooth gaps are more consistent between cogs. you still retain 11, 13,15 as the 3 smallest cogs so there is less of a cadence jump between the faster gears than the 10sp converted cassettes which went 11,13,16,19....
This all gets you within 3% of an XX1 cassette's range at a lower price without having to worry about XD freehub/driver issues.
The idea behind One-up's conversion is that, compared to XX1, the 45t granny allows you to run a bigger front chainring which in turn gives more speed in your smaller cogs, somewhat negating SRAM's 10t advantage.
Edited by JXV
