making a bike more quiet?
Mongooser
Hi hubbers
anyone here have any good tricks to make a bike noiseless/quiet
I have a DH rig and i want to make it quiet as it can be
got 2 chain protectors on the rear triangle already and ductape all around the corners of it to
replaced all my bushings to so nothing from my linkage either
bike still not quiet enuf random things are making tiny noises
what you guys do to silence your rig?
like in the vid
If you can hear your bike, you not going fast enough
sorry, not friday yet ?
hahaha Cole definitely goes fast/hard enough!
My secret is being deaf... that way I don't really hear the squeaks and moans unless they are really bad.
Cables slapping also makes a noise, and it is worse in internally touted frames.
Not if you build it properly. Spez supply thin foam tubes to shroud the cable housing, which works wonderfully. Should be standard on every bike IMO
Hi hubbers
like in the vid
if i could ride like that oke my bike can make as much noise as it likes. But yes I know what you're saying - bike rattling grinds my t!ts as well. Worst place for me is Tree Charge at Conters.
Interesting. I suspected the rattle on my duel was from the internal cabling. Going to give this a try thanks
