Road tyre brand and model, width, your body weight and tyre pressure
Mamil
  • Replies 75
81kg
Continental GP 4000  ((n my opinion a better tyre than the GP5000  :ph34r: )
28mm (Scott Foil rim brake  / Supersix rim brake)
rear 6.2 bar
front 5.9 bar
you one of the very few people who think that...
Real question:
There are some very precise measurements being quoted, but how accurate are they ?
I tried two pumps and their (analog) gauges differed by about 10% and neither was what my digital Topeak read.
I am going with the digital one.
I have to aggree with you RE the 4000 and 5000 - my 5000's felt horribly squishy and unstable and punctured frequently. Wasn't happy.
81kg
rear 6.2 bar
front 5.9 bar
I don't think 100% accuracy is that much of a factor. Most of us will use the same pump all the time so the relative pressure will be the same not so?
Weirdly I have 2 pumps. One is for the roadies and one is one of those air tank boys and that lives with the mtb's.
Wow, that must an absolutely terrible ride! Why on earth would you pump them so hard?  :eek:
 I have just always had them at that pressure and don't like the feel of soft tyres. I ride my 25mm tubbies at 9 bar!
You mean you don't like the feel of comfort and grip while cornering?  :eek:
To be honest never tried lower pressures. I just sort of inflate to just below the suggested max on the tyre.
I'll drop the pressures for this weekend's ride and see.
25mm GP4000s II
Tubolito Tubes
Weight: 69kg
TRAINING
Front: 6bar
Rear: 6.3bar
RACING
Front: 6.6bar
Rear: 7bar
all about gaining comfort on my training rides.
in races i inflate higher
you have not lived. might be slightly more rolling resistance, but the comfort gained is something you cannot turn your nose up to. especially if its a training ride
Pretty much all of the studies show that lower pressures have lower rolling resistance on everything except perfectly smooth roads so inflating your tyres harder doesn't even give you less rolling resistance unless you are doing track cycling.
all this talk of rolling resistance of fatter lower pressure tyres, has there been any studies that look at the aerodynamic pros/cons of running fatter rubber ?
Link to these studies, please? Keen to read them.
