Hoping for some advice or other "hacks".
I've noticed this weekend that the screw that holds the Shimano Deore shifter together has gone AWOL. After testing some screws/bolts at home I've found it's a 5mm and some Googling has proven that I am in search for a M5 bolt of 8mm in length. I've been to builders and every hardware shop around the West Rand and Zilch for a button head of that length.
Has anyone had a similar problem and managed to get it sorted?
you want to go to a specialist fastener/engineering supply place. I'm in Cape Town so don't know the Jo'burg places
16 hours ago, Alouette3 said:
Do you have a pic of the bolt? Got a couple bust up shifters here that might have what you after?
Hi
So i've added a pic of the shifter and the bolt that seems to be required.
I don't have one of those unfortunately, but you will definitely pick one up at a bolt and fastener supplier. In the Cape we have the likes of Bolt Fast, Top Fast, Bolt it. You may  just need to grind down the thread length a little if you can't find 8mm
Thanks for checking anyway, appreciated. I have some leads and will chase them down.
